HHR LS Swap Rat Rod
Old Nov 12, 2017 | 08:24 PM
  #211
That rear end is going to be really "squirrelly". The weight distribution is wild.
I didn't expect the motor to be that far forward.
Old Nov 13, 2017 | 08:02 AM
  #212
What happened to your header idea?
Old Nov 13, 2017 | 08:53 AM
  #213
RattyHHR's Avatar
Yeah regular cruising should be fun. This is gonna be a work vehicle most of the time, so the back should have enough weight loaded down to be stable and safe. My engine and transmission don't weigh enough to compress the suspension. With my 220lbs standing on it, the front suspension begins to drop. It appears to need about 350 lbs total on the front just to get the suspensions to a normal height. The rubber bump stops aren't in the a arms, and right now the bottom of the upper a arm is touching the frame.
I'm gonna get my radiator and front bumper and everything on before I do any suspension adjustments, but I'm thinking I might have to at least cut a coil off the give me proper suspensions travel.
I wanted to use those headers OldBlue, but I found a killer deal on these. Maybe one day. Looks like my electrical box might have interfered with those headers.
Old Nov 13, 2017 | 09:03 AM
  #214
Cat Man HHR's Avatar
How much does the front have to drop?
There are lowering springs and dropped spindles if need be.
Cutting the coil will produce a much firmer spring rate then the spring already has.
Old Nov 13, 2017 | 09:26 AM
  #215
RattyHHR's Avatar
It looks like it needs to drop 3 inches or so at regular ride height to utilize all of the suspension travel.
Old Nov 13, 2017 | 09:58 AM
  #216
How about making your front bumper out of black pipe and filling it with sand?
It is a rat rod.
Just as a test jack up the body in the rear to change that ride height and look at the control arms. Jacking up the back will put more weight towards the front.
Or put smaller wheel/tire on the front to match the back.
By the picture is the floor jack holding up the rear of the trans?
Old Nov 13, 2017 | 10:09 AM
  #217
RattyHHR's Avatar
It is a rat rod.
Great minds think alike!! I'm thinking about making a bumper/grill similar to the old cattle grills on trains that would clear the tracks. I tried jacking the back up, but my eyes in the front said no change. I'm gonna see how it does next weekend when I get the rear end in.
Old Nov 13, 2017 | 10:43 AM
  #218
Way back when when I raced bomber cars (cheap stock car) I made a cow catcher out of pipe from a fence. Worked quite well.
The rule book was an 8 x 12 piece of paper and you were aloud to protect the radiator.
Pushed many out of my way.
Old Nov 13, 2017 | 12:28 PM
  #219
RattyHHR's Avatar
So this bumper is perfect for my displeasure in traffic
Old Nov 18, 2017 | 12:12 PM
  #220
RattyHHR's Avatar
Cat, any idea what this is? Guy drilled a hole to drain the fluid. I've got a drain plug installed now. This was in the bottom of the pan when I dropped it. It has a recessed hole about 1/4" around, but doesn't go all the way through. I'm hoping it's a plug he put in the hole that got pushed through. Wanna make sure it doesn't go in any of the working parts.
