HHR Panel drivers...
Old Jun 27, 2008 | 07:17 PM
Duncan's Avatar
Originally Posted by mongo
I don't use the 'bugspotter' mirrors, but I've been driving full siize vans my entire adult life so the blind spots are not an issue on a smaller vehicle for me.
Same here. I also have an Astro Cargo Van and consider the stock mirrors on my HHR panel to be quite good.
Old Jun 27, 2008 | 08:18 PM
Cyclic Hardover's Avatar
Originally Posted by WellArmedSheep
Going to pick up my new Panel tomorrow morning and I was wondering how many of you use the little round stick-on convex mirrors on your stock outside mirrors to help with blind spots. I thought about picking some up on the way tomorrow and sticking them on in the parking lot.
I've used them on every vehicle I've owned for years. I have the reg HHR and use them, They're onmy Vette, Acura, Kids car.
I install them on both sides. I never look out the side windows for other cars, These work fine.
Old Jun 27, 2008 | 08:34 PM
Li'l Hearse's Avatar
I only have a blind spot when I back out of my driveway. (Can't see through solid metal!)First couple of times,I almost backed into someone! I drove tow trucks for years and an Astro Van at work,now,so I'm used to using mirrors. When I merge I sometimes hit the power mirror button.
Old Jun 28, 2008 | 08:23 AM
gravett1's Avatar
Smile
I've been driving my panel for 10 months & never needed them.
Old Jun 28, 2008 | 08:25 AM
Jeff®'s Avatar
ME!
Every car I own or have owned has one. I wnt in to the dealer when I took delivery of mt HHR with one and stuck it on before leaving.
Old Jun 30, 2008 | 05:27 PM
Surfer Panel's Avatar
May want to "soft mount" whatever you first get and see if that works for you. You may get used to the limited vision of the panel and stock mirrors and not need aux convex mirrors.
Whatever you do -- I welcome you to the 2-seater club !!
Let the Mods start........
Old Jun 30, 2008 | 05:38 PM
hvrod's Avatar
I use these
which are also spliced into my turn signals..
Old Jun 30, 2008 | 08:05 PM
WellArmedSheep's Avatar
The little round mirrors are coming in handy. Blind spots are negligable, and backing out of parking spots is alot less stressful than I thought it'd be. I like those with the turn signal arrows, hvrod...where'd you get em?
Old Jun 30, 2008 | 09:56 PM
hvrod's Avatar
http://www.muthco.com/products/kits/220-0056.htm
Theres the site ... I had these on for a long time first my 2006 and now my 2008.. Lets people on the side of you see you signaling, and the mirrors allows you to see in those blind spots..
Its a bit of labor intensive chore to install. First you have to carefully remove your mirror, remove the door's panel, remove the mirror housing, and snake in the wiring thru a tight hole opening then out. Then splice the wire to your turn signal wiring....
pstar
Jun 9, 2014 06:14 PM
solman98
May 22, 2009 08:18 PM
solman98
Oct 13, 2007 09:50 AM
mrbcruzn
Jul 3, 2007 07:42 PM
