How long can you charge a USB device?
Old Dec 23, 2015 | 07:50 AM
db/sb's Avatar
I have one of those in my Ranger that I leave plugged in. After a three week Texas vacation, it started right up when we returned. The drain is minimal as pg318 stated; far less than the security system which is on all of the time.
Old Dec 23, 2015 | 09:02 AM
I have gotten away with leaving my inverter turned on all weekend; but, sometimes leaving the headlights on for (using the switch) for 20 minutes will kill the battery.
The USB adapter reduces the 12V to 5V, so less drain than you might assume.
If there is no load on the adapter there is no drain.
Old Dec 23, 2015 | 04:00 PM
Blue_SS's Avatar
except for the power light, if he has one
Old Dec 23, 2015 | 04:56 PM
db/sb's Avatar
Even with a power light, which mine has, there's negligible drain. It's an LED.
Old Dec 24, 2015 | 03:54 AM
hhr06NJ's Avatar
Originally Posted by pg318
The standby current on those USB adapters is usually pretty small (a few milliamps), I leave mine plugged in all the time, I suspect that the biggest drain is probably the LED status light on it.
I do the same.
AND
I left phones charging overnite OR
a (small) GPS on overnite no problem
Old Dec 24, 2015 | 05:33 AM
bugo's Avatar
My adapter has 2 USB outlets but thankfully no LED. The only thing I don't like about it is that sometimes it comes out of the socket by a few millimeters and loses connections. I constantly have to make sure it's plugged in all the way.
goetylsd
Jul 27, 2010 08:37 AM
Cyclic Hardover
Jun 20, 2008 09:24 PM
Goose
May 16, 2007 10:19 PM
Dave Carney
Sep 29, 2006 09:19 PM
hvrod
Jul 13, 2006 01:59 PM
