Interior Noises.
Old Nov 29, 2007 | 07:26 PM
Biggiedog70's Avatar
Interior Noises.
Does anyone elses Door panels vibrate and make make noises, this drives me crazy. Everything is tight, there just seems to be some play not much, between the door and the panel, I think I am going to try putting some small peices of rubber between them to see if it helps. Seems all for doors do it, not all at once though
Old Nov 29, 2007 | 07:45 PM
mynameistaken's Avatar
You sure its not coming from the headliner?
https://www.chevyhhr.net/forums/problems-service-repairs-42/noisy-roof-headliner-5124/
Old Nov 29, 2007 | 07:55 PM
Def. not the headliners, its the doors on mine, i can press on them and the noise goes away, so i know its the doors for sure.
Old Nov 29, 2007 | 11:24 PM
Dan's HHR's Avatar
crank up the radio
Old Nov 30, 2007 | 08:08 AM
I do crank it!!!
Old Nov 30, 2007 | 09:00 AM
dbfruth's Avatar
Same thing on my car. I need to take the door panels off and see if I can find what is causing the squeaks and rattles. I also have the headliner issue but that is going to the dealer. Mine sounds like a wire is loose and rattling when it touches the headliner.
I also have rattles and an occasional clunk from the cargo area. I'll probably have the dealer look at that too.
I know I am probably hyper sensitive to this stuff.
Old Nov 30, 2007 | 10:05 AM
playgames1970's Avatar
The door behind the driver used to click and pop, but it has since settled into place and has quieted itself. Just be glad it's not the headliner...I had noises in mine over bumps that went beyond problems with the Velcro...my liner was manufactured wrong and had to be replaced entirely! Good luck with the doors!
thegodfather
Oct 18, 2011 10:00 AM
TiggersHHR
Mar 14, 2011 12:22 PM
meriquillo
Dec 6, 2008 07:04 PM
Scrivs
Jun 20, 2008 08:07 PM
Programmer
Jun 15, 2008 02:53 AM
