Leak in back of HHR
Old Jun 18, 2025 | 09:59 PM
greg8453's Avatar
Originally Posted by alweasel
He also said something about gas or gas vapor at the front of the car or engine when I shut the car off it goes back to the gas tank and that may be it.
But then again The poor guy was dealing with a total car moron.
Sorry all. I really am a car moron.
That would be the return line for the fuel.
Old Jun 19, 2025 | 09:23 AM
What return line?
Old Jun 19, 2025 | 09:47 AM
greg8453's Avatar
There are two fuel lines one liquid and one vapor. Unless the canister is flooded it'll be the return line.
Old Jun 19, 2025 | 11:20 AM
Vapor from the tank goes to the intake manifold, it is not a return line like on a diesel.
Vapor from the tank goes into the charcoal canister where it is stored until the EVAP purge valve opens, the vapor is then sucked into the combustion chamber and burned.
The only way there could be fluid in the vapor line is if the charcoal canister somehow got flooded with fuel. That would cause other more serious symptoms. When that happens from overfilling the tank the usual result is charcoal pellets in the tank.
Old Jun 19, 2025 | 12:13 PM
greg8453's Avatar
I was referring to the fuel return. If the can is soaked it will leak raw fuel.
Old Jun 19, 2025 | 12:16 PM
greg8453's Avatar
Fuel Return Line: Service and Repair
Fuel Hose/Pipes Replacement - Chassis
Removal Procedure
1. Relieve the fuel system pressure. Refer to Fuel Pressure Relief (Without CH 48027) (Fuel Pressure Relief (Without CH 48027))Fuel Pressure Relief (With CH 48027) (Fuel Pressure Relief (With CH 48027)).
2. Remove the air cleaner assembly. Refer to Air Cleaner Assembly Replacement (Service and Repair).
3. Disconnect the fuel feed pipe from the fuel rail. Refer to Metal Collar Quick Connect Fitting Service (Metal Collar Quick Connect Fitting Service).
4. Cap or plug the fuel pipe and the engine fuel rail to prevent contamination.
5. Disconnect the evaporative emission (EVAP) pipe from the purge solenoid. Refer to Plastic Collar Quick Connect Fitting Service (Plastic Collar Quick Connect Fitting Service).
6. Cap or plug the EVAP pipe in order to prevent contamination.
7. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle (Service and Repair).
8. Remove the evaporative emission (EVAP) canister, if necessary. Refer to Evaporative Emission Canister Replacement (Service and Repair).
9. Disconnect the fuel feed pipe quick connect fitting. Refer to Plastic Collar Quick Connect Fitting Service (Plastic Collar Quick Connect Fitting Service).
10. Remove the brake lines from the fuel/EVAP/brake line brackets.
11. Remove the fuel/EVAP/brake line bracket nuts and remove the brackets from the body studs.
12. Remove the fuel and EVAP lines from the vehicle.
13. Open the brackets and remove the fuel feed pipe.
Installation Procedure
Old Jun 19, 2025 | 01:07 PM
Do you "top off" your fuel tank?
Old Jun 19, 2025 | 03:22 PM
alweasel's Avatar
not really.
I have a 50 mile one way commute to work.
I try and Fill it at quarter or more since my commute is nuts.
I have not seen a huge difference in gas mileage.
I will make sure and check on it more next week.
Thanks He was saying something vapor. Im just to stupid on cars to understand.
But I love this car and want to drive it until its dead.
Alan
Old Jun 19, 2025 | 03:58 PM
Have him change the fuel and vapour lines, as I posted earlier. It’s an easy job especially if he has a lift! The vapour line won’t leak gasoline just vapour from the gasoline.
Old Jun 19, 2025 | 08:44 PM
greg8453's Avatar
not really.
Alan
We have explained the two lines. The vapor line is for your EVAP system and the other are for fuel delivery from the gas tank.
