LED Dome Light
Old Jan 23, 2007 | 08:36 PM
HHRACER's Avatar
did they have it in red?
Old Jan 23, 2007 | 08:42 PM
Applenut's Avatar
this one may help
https://www.chevyhhr.net/forums/appearance-modifications-discussions-6/little-light-blue-led-2853/
Old Jan 23, 2007 | 08:47 PM
mizzouHHR's Avatar
Originally Posted by oneton
Is there a post on how to get it down to replace LED ?
It depends. If you have a sunroof, then you just have to pinch the sides of the plastic piece the light is in and pull down. If you don't have a sunroof you have to drop the headliner and remove from the top. This involves taking off the A pillars and visors. I had to also take the wire that goes to the light and pull it off the headliner. It's glued and you can take it off if your carefull. Then you have to feel for a clip and pull it back towards the front of the car, and the piece the light is in pops out. you can pull it out from under the headliner now and remove the LED (it just pulls out). Then trim the wires on the new bulb to fit and plug it in, making sure it is the right way (it won't work if it's backwards). Just remember to be very carefull with the headliner becouse the foam board will break.
Old Jan 23, 2007 | 08:54 PM
mizzouHHR's Avatar
The only red I found was a 12 volt, and was very dim. I tried installing it first, so it would match the color of the exterior of my car, but it was so dim you couldn't see the window switches, or anything else for that matter. The blue LED worked much better.
Old Jan 23, 2007 | 08:56 PM
oneton's Avatar
Thanks all no sunroof looks like take it down if I want to change
Old Jan 23, 2007 | 09:02 PM
  #26
mizzouHHR's Avatar
It's not really as hard as I may have made it sound. I'll say again just take your time and be carefull. One more thing, if you have the grey interior make sure you have clean hands, and keep them that way. The grey shows dirt and is hard to clean.
Old Jan 24, 2007 | 06:10 AM
  #27
WickedHHRLT's Avatar
that light doesn't bother me at all, I like that its on, if I need to glance at something, I can keep my hands on the wheel, and see what i need to see with quick glances.
Old Jan 24, 2007 | 11:14 AM
  #28
Black Rose's Avatar
Originally Posted by Applenut
You'd think they would have been able to do the minor re-engineering for the '07 year though......darn companies trying to save a buck!
I used to think that way as well, but now that I have been doing contract work for GM for the last year and have a better understanding on how they do things, even what appears to be a simple change to us is not as simple as it seems.
Old Jan 24, 2007 | 07:41 PM
  #29
Applenut's Avatar
Don't get me wrong, I understand how something so simple can be a pain to change, this is a BIG change in many things (wiring/parts/process in assembly ect.). But............I secretly still think they should fix it.
Old Jan 28, 2007 | 07:23 PM
  #30
Applenut's Avatar
I broke down and replaced mine
