Losing oil through exhaust
Old Nov 7, 2018 | 09:28 AM
If everything in the exhaust path is clean i.e.:O2sensor, tailpipe, spark plugs What proof is there for out the exhaust?
Old Nov 7, 2018 | 09:37 AM
Ohiocruiser's Avatar
exhaust tip is all oily.
Old Nov 7, 2018 | 09:41 AM
DrLoch's Avatar
Have you changed the brand oil that you are using?
Old Nov 7, 2018 | 10:17 AM
no. Mobil1 5w30 since I've bought it with 20k miles.
Old Nov 7, 2018 | 11:01 AM
My personal experience is that Mobil1 burns away faster than some others. Yes it is the recommended brand, however the spec has been updated. At the time of manufacture there was only one.
Old Nov 7, 2018 | 03:23 PM
well it was working fine for me for the last 87k miles. Didn't burn or loose a drop untill recently.
Old Nov 11, 2018 | 06:02 PM
Little update. That was what I notice and replaced today. It is turbo oil drain line. Is that possible for that bend to reduce oil drain enough to damage the turbo?
Old Nov 11, 2018 | 06:36 PM
Is there any damage from those gear clamps allowing oil to leak ?
Old Nov 11, 2018 | 06:51 PM
that was upper end closer to the bend. And it was wet. Since there's no oil pressure there, I am guessing it was "flooding' the shaft. Correct?
Old Nov 11, 2018 | 07:25 PM
Possibly, I suggest replacing the hose and change to better clamps like this style
