Loud tapping/rotating noise when cranking
Old Sep 28, 2011 | 12:34 AM
Silver11's Avatar
Unhappy Loud tapping/rotating noise when cranking
2011 2LT
When cranking and shutting down inside the car it is making a tapping/rotating noise. Also very very audible on shutdown. During driving it it there especially going down hills and braking not noticable on acceleration comes and goes at speed. No performance decrease, if anything after we hit 15k total miles it seemed to start running and accelerating much better.. who knows. Any help on this before I roll into the dealer and waste a day or 3 there would be welcomed.
Also any way to get GM Service to just fix all the TSB's on your car or do I need to "complain" about and reference each one?
Thanks
Old Sep 28, 2011 | 01:11 AM
I'd say have it looked at as soon as possible. Checking the service manual for a similar condition brought up the possibility of a broken valve spring, a stuck valve, a stuck lifter, a jammed oil filter bypass valve, low oil pressure, a failing oil pump, a blocked oil pump intake screen, bad timing chain tensioners, and a stretched timing chain.
Not trying to freak you out, but since you are hearing the noise during startup, shutdown, and various engine speeds...its pointing to a possibly serious internal issue with the engine.
Old Sep 28, 2011 | 01:20 AM
Snoopy's Avatar
Originally Posted by Silver11
2011 2LT
Thanks
TSB's are informational to the Tech.'s and assist them in a repair when a problem may EXIST in a specific area. THEY ARE NOT REGARDED AS RECALLS OR WARNINGS THAT A PROBLEM DOES EXIST.
Old Sep 28, 2011 | 08:03 AM
oneton's Avatar
Thank You Snoopy, I read about TSB's in post all the time and find it humorus. Some think that they need to bring it to the dealer to get it repaired .
Old Sep 29, 2011 | 01:34 AM
Silver11's Avatar
Could not get in the dealership today. Going in the morning. Will post up with what the problem was/is. Wish me luck cause this old man loves his little HHR!!
Old Sep 29, 2011 | 05:38 AM
frank6060's Avatar
It could be poor fuel quality also giving you an octane knock. Try a different brand or a higher grade octane fuel.
Old Sep 29, 2011 | 01:08 PM
Silver11's Avatar
Loose exhuast bracket. Everything is running fine. Had them check a few things here and there no issues, got my second key fob and new owners manual. Nothing to do but drive the ol silver girl and put that ss spoiler on it in the next 2 months!!!
Old Sep 29, 2011 | 02:42 PM
Glad to hear it was something simple and minor Silver.
ChevyBoi
Mar 8, 2023 03:31 PM
futureladycop227
Jul 17, 2013 01:47 AM
Joepoppa1
Jan 31, 2012 01:29 AM
DrummerHHR
Jul 11, 2011 12:31 PM
Lake Runner
Dec 4, 2010 07:45 PM
