Maximum speed limit? speed limiter on HHR?
Old Apr 30, 2010 | 02:42 PM
stranger's Avatar
Guys.....I'm thinkin' "the" Big bro and the builder kinda look at things this way....... the vehicle has "X" type tires, the drive train is able to handle this much rotating velocity and the length and width in relation to the handling limits of the vehicle equals this max mile per hour....... what I'm sayin' is it's not a random number they select because of how they felt on that day. Now rental cars......everyone I've seen rented had the "go" pedal oulined imprinted on the carpet....... choke her back, you bet!
Old Apr 30, 2010 | 04:45 PM
ChevyMgr's Avatar
Originally Posted by slimsol
Thanks for all your reply. Do you think a dealer with fix this limiter issue without charging? the car is still under full warranty. But because the limiter is a "ADJUSTMENT" not a "FIX"
The vehicle was not built or designed to only go to 80 mph. So it's a defect and they should fix for free. But if someone has done this after the vehicle was built they may not fix for free. Was this a rental/fleet car? If you don't know give me the last 8 of your VIN and I can check it out.
Old Apr 30, 2010 | 04:51 PM
Pretty sure the original post said it was a rental........ If they did this, it's more a mod than damage/defect.
Old Apr 30, 2010 | 05:05 PM
ChevyMgr's Avatar
That bites, but I still have never heard of this being done. And if it was a national rental chain, I have seen cars for all of them and never heard of this.
Old May 1, 2010 | 09:28 AM
slimsol's Avatar
It was owned by a renting company called "national rental company". I bought it directly from them and carfax also says that it was a rental car. I did some research and i found hat something like "hypertech" can remover speed limitation from my car. is it something i can do it by myself?
Old May 1, 2010 | 09:41 AM
  #26
urbexHHR's Avatar
Sounds kinda like the things the fly by night used car lots put on the engine to make it not start if you don't make your payment...
Mcw032391
Jun 1, 2012 08:37 PM
goetylsd
May 4, 2011 11:51 PM
09_SS
Nov 20, 2009 01:04 PM
1lowlesabre
Jun 4, 2008 04:03 PM
