Okay, who farted?
Old Nov 7, 2008 | 07:21 PM
  #31
halfpanel08's Avatar
Originally Posted by 08BlkSS
Cabin air filter?
Are you kidding , or serious ?!
(but its okay cus i wasnt aware what "dryer sheet" meant)
Old Nov 7, 2008 | 08:47 PM
  #32
Premiere07's Avatar
Not to keep bringing it up but the smell comes from the MILDEW in the ducts, you HAVE to kill the MILDEW if you want the smell to be COMPLETELY gone.
Adding air freshners is just putting a band aid on an amputated arm it might cover it up but it DOESN'T fix the problem!! Kill the mildew, kill the problem!!
Old Nov 7, 2008 | 10:28 PM
  #33
suburbanjunior's Avatar
I brought mine into the dealer and they disinfected mine and have not had any trouble since then. I think it was sept of 07.
Old Nov 7, 2008 | 10:45 PM
  #34
TEB-HHR's Avatar
Originally Posted by jx3
This is exactly why this site is so GREAT! Anyone can learn anything about their HHR just by reading/surfing or asking. Thanks to all I had no clue as to where the cabin filter was. Tomorrow I will go look at it. I think I will also look for the battery while I'm at it, again I have no clue :-)
Old Nov 8, 2008 | 09:49 AM
  #35
bigdog9586's Avatar
This can be a common problem when only using the recirculate mode. Always switch it from recirculate about 5 minutes from the end of your trip as it will then use all fresh new air and dry out the ducts better. This seems to be a big problem on some of the Toyota sites and they recomend not using recirculate at all.
Originally Posted by Premiere07
Turn your a/c on recirculate, aim a can on Lysol into the intake vent for the a/c close to the floor, spray a good bit, turn the car off let it sit for a while, turn your a/c back on and let it circulate again, spray a lil more, then turn it off and leave it off.
Should be fine after this, common issue, you just have some mildew growing and surviving off the condensation in the duct-work. Next time run your vent for the last 5 minutes of your trip or so to help lower the amount of condensation in the ducts.
Old Nov 8, 2008 | 10:06 AM
  #36
JimZ_HHR's Avatar
where's intake vent?
Old Nov 8, 2008 | 10:35 AM
  #37
Premiere07's Avatar
Yup should have been a product called "Fridge-Fresh" or something similar, but it is nothing more than a disenfecting spray such as Lysol. And the technician would do the EXACT procedure as I stated earlier.
As far as the recirculation intake goes, it is under the dash on the passenger side floor board. It is a black plastic duct that has an angled cut on it.
Old Nov 8, 2008 | 04:48 PM
  #38
Marzipan's Avatar
Picture shows leaves on the filter. My 2008 has a fine mesh screen on the intake (near the windshield wipers) which would block leaves. This may be an enhancement since the 2006 models.
Old Nov 9, 2008 | 08:50 PM
  #39
Dory has been through at least 4 hurricanes and 3 tropical storms, you'd be surprised where 75+ MPH winds will force leaves!
Old Nov 9, 2008 | 09:07 PM
  #40
i have a 2008 and i had leaves n my filter when i checkd it
