Power problem to power outlet on dash
Can someone tell me what fuse is associated with power outlet on dash in front. No power at receptacle so I have to plug in radar detector in power outlet on console. Please help!
if its not the fuse..pull the waterfall and have a look at the connection harness to the lighter..Ive had er come loose once..seems the mexican builders had this problem with alot of the connectors and fuses,,Ive found a few loose ones..just push..all fixed..
weekendwarrior
Jan 20, 2011 08:35 PM
