Question about cabin air filter
Old Oct 24, 2013 | 04:16 PM
Silverfox's Avatar
Originally Posted by donbrew
It's in the Owner Manual. It also always runs if the defrost is on in either positition.
Yeh I knew about the defrost positions.
Owners Manual ??
Whats That ??
Old Oct 24, 2013 | 04:18 PM
skyline26's Avatar
cant remember the name of the product i used..but its like a smoke bomb/spray. Have the car running with recirc on and all windows up and you push down the spray button and once its engaged it just keep spraying until its empty..takes about 20mins or so of running the car with it recirculating but it did the job for me :)
Old Oct 24, 2013 | 04:28 PM
Silverfox's Avatar
Are you sure It didn't just cover up the smell that was there with another smell that wasn't ??
Thats what FaBreeze does even though the company gets Irrate if you call and point it out to them.
SF
Old Oct 24, 2013 | 08:08 PM
Go to Home Depot in the cleaning chemicals aisle look for ZEP Smoke Odor Eliminator aerosol. It does actually work.
Old Oct 27, 2013 | 09:24 AM
bduemig's Avatar
I just changed my filter. I found a few videos on how to do it. One says to remove the screw on the actuator rod before releasing the stop clips to lower the glove box. This is not necessary and becomes a bit of a pain to reconnect it.
To replace, leave the actuator screw in place and just hit the two stop clips and the glove box swings down plenty far enough to change the filter.
Old Oct 27, 2013 | 10:12 AM
From the owners manual: (nothing about removing a screw)
To access the passenger compartment air filter:
1. Open and empty the glove box.
2. Press both glove box stops outward to let the glove
box drop open completely.
3. Pull the three tabs of the filter access door down
and open the access door downward.
4. Pull the filter out, keeping it upwards.
Install the new air filter with the AIR FLOW arrow
pointing downward. Reverse Steps 1 through 4 to
reassemble.
Old Oct 27, 2013 | 06:45 PM
skyline26's Avatar
no it didnt mask the smell at all, i wish i could remember the name! but its like an aerosol type spray almost like Lysol spray cans, leave it in the cup holder close the doors with recirc on and let the can just empty, sucks it into all the vents and eliminates odors and bacteria etc
HonestBlues
Mar 17, 2014 05:45 PM
Retroburban
Maintenance and Upkeep
69
Jun 11, 2011 01:41 PM
camaro98z28
21
Sep 12, 2010 10:12 AM
Lil Cheney
Jul 5, 2009 09:06 PM
Gr8ful
Mar 19, 2009 10:02 AM
