The rear view mirror placement problem
Old Feb 8, 2006 | 08:05 AM
captain howdy's Avatar
Originally Posted by jx3
OK...BACK TO THE THREAD TOPIC....
I tried this pushing firmly , all that happened was popping the mirror off its base on the windshield.
It looks like you pressed a little too firmly! Is the mirror broken or were you able to snap it back together?
Old Feb 8, 2006 | 08:16 AM
The mirror itself just snapped back on, but the little plastic piece that hides the wire was a bit problematic. Need small hands to fit between mirror and windshield.
Old Feb 8, 2006 | 08:56 AM
wheelsee's Avatar
it's on sort of a double hinge...if that helps one is right behind the mirror itself and the other is at the base near the windshield...
-wC
Old Feb 9, 2006 | 04:59 PM
chrishicks's Avatar
so my wife is on her way home after picking up the car from the tint shop and the mirror is all out of place. she tried to move it and she said it won't budge. she says its about 2" lower than before because all she sees now is the backseat. how much pressure is recommended to move this because I don't want to break it off the windshield?
Old Feb 9, 2006 | 05:29 PM
SoCalHHR's Avatar
I would say to hold the mounting plate firm before you push. I had no problems moving mine with a firm nudge, but one member broke his off! Try holding the base while pushing on the pivot bar. Once it starts going it will move freely up.
Old Feb 9, 2006 | 06:04 PM
chrishicks's Avatar
man that mirror is stiff. I kept pushing upward on it little by little until it started to move. it does take a bit to get it going but once it started it was all fine. thanks.
Old Feb 9, 2006 | 06:08 PM
SoCalHHR's Avatar
I hear you! No danger of it moving when you hit a bump!
Glad to hear you got it re-arranged.
Old Mar 6, 2006 | 11:22 AM
slikRick's Avatar
Junior Member
MIKE thanks for the mirror tip ! I havent run over anyone since I moved it !
Old Mar 6, 2006 | 12:11 PM
SoCalHHR's Avatar
Glad it helped save a life or two!
CJ3
Dec 16, 2013 04:41 PM
aeroned
Mods - Interior
Dec 5, 2011 09:39 AM
JuMPy
Jul 9, 2010 10:19 AM
asherdav
Jun 16, 2010 11:49 PM
