remote start
Old Sep 12, 2024 | 01:58 PM
Look at post #22, in the thread, he states that the wire you need to scrape the insulation off and ground is a purple wire in the BCM area of the waterfall, not under the hood.
Old Sep 12, 2024 | 02:14 PM
Eskimos's Avatar
Originally Posted by donbrew
As Oldblue pointed out PURPLE not pink. Somewhere in that link there are pictures. Look at post #199 for a summary.
Does the speedo go to 120 or 200? 200 would be Euro.
Awwww… PURPLE! Not pink!
Grounded PURPLE and it works OK!
Thank you, gentlemen, very much!
Some time ago I was struggling with an aftermarket radio installation and there was a PINK wire to tap into so it must have confused me.
Again, thanks!
Old Sep 12, 2024 | 02:26 PM
PulpFriction's Avatar
Glad it worked!
BTW, you probably already know that now, the 4-button fob with the remote start button will work, if you want to avoid two-handed multiple button pushing gyrations. Less onviously, the contact is already on your green board and you can simply move it to an empty 4-button case, available cheap on line.
Also, I would highly recommend posting a prominent warning under the hood that the RS remains active with the hood open. I also put a note in behind the fuse panel that explains the ground wire.
For future reference, here's another thread, with a pic (and links to even more threads, and only a few entries to get through):
https://www.chevyhhr.net/forums/gene...-rental-62024/
Re: colors - the conversation had me wondering if there was a translation problem.
Old Sep 12, 2024 | 02:45 PM
Now I am really confused. are the letters or the dresses the color stated? Is pink purple or is purple pink?
Old Sep 12, 2024 | 03:01 PM
Eskimos's Avatar
No, no, I know the color names and the difference :)
Two weeks ago I was installing new aftermarket head unit and to power the factory Pioneer amp I had to tap into PINK wire in the radio harness and that PINK must have really stayed in my head :)
New, 4 buttons FOB shells are already on their way 👍
tahenke
Aug 26, 2018 03:14 PM
sttcharl
Nov 21, 2010 04:07 PM
Daytonablue06
Jul 6, 2010 09:23 PM
prod
Dec 10, 2008 09:32 PM
keverz146
Mar 12, 2007 10:56 PM
