Rocker panel clips, left blinker
Hello again everybody. It's been awhile. I'm trying to order some rocker panel clips for an '06 since most of the ones that were there got sheared off thanks to some road debris. The problem I'm having is everything I'm finding says they fit a 1/2" hole. The existing holes are 3/8". Anybody know if they'll work or should I be looking for a different part. While I'm here, has anybody else had problems with their left blinker not automatically shutting off and if so, is the fix done fairly easily? This is happening on both my '06 and '07 models.
I'll have to call them tomorrow and check on the part # for the clips I guess. I also found a thread on flipping the spring inside of the signal switch so I'll try that before I buy the new part.
teufeldog0231
Jun 11, 2016 08:45 AM
