Source for HHR cover.
Covercraft makes a nice one, I have an Evolution 4 cover that I use when we stay overnight somewhere with one of the HHR's, keeps 'em clean and away from prying eyes.
Found the best price here....
http://www.autoanything.com/
One hint, the first time you install the cover, have a helper since they are a little stiff when new. Also, even though there is a pocket for the antenna, its easier just to unscrew it and stick it inside rather than trying to coax it into the antenna pocket until the cover is "broken in" after a couple of uses.
When you install the cover I've found its a snap when you get the mirrors in their pockets first, then the nose, and finally the rear end. When its on you'll find that it tucks in and covers everything except about 2 inches of the sidewalls at the bottom of the tires.
