Steam Clean Engine
Old May 17, 2014 | 07:02 AM
Lawagz's Avatar
Steam Clean Engine
Hi,
I have an '08 2LT with 2.4 automatic. Are there any special precautions I need to take if I decide to have my engine steam cleaned and what would something this normally cost to have done?
Thanks
Old May 17, 2014 | 08:39 AM
Give this thread a read...
https://www.chevyhhr.net/forums/appe...ng-tips-13364/
As far as cost to have it done, give a couple of your local detailing shops a call.
Old May 17, 2014 | 08:51 AM
Lawagz's Avatar
Thanks for the link, I appreciate it! Good read and I think I will contact some detail shops as I don't have mechanical inclination whatsoever and would be too worried about "mucking" (replace one letter with "F") :) it up!
Old May 17, 2014 | 08:57 AM
then let those detail guys clean her up, that's what they do for a living!
Old May 17, 2014 | 11:55 AM
"steam" cleaning engines is pretty much the same as "steam" cleaning carpets. You spray a bunch of your favorite de-greaser (Green,Red, Purple etc) on everything you can see, let is sit for a while then hose it down with hot water. Scrub any stubborn parts.
Plug up intake tubes. Remove the air intake hose, or it will be destroyed. No distributor, so no worries about electronics getting wet. There is supposed to be a large paper broadcast label on the head, it will probably be lost, it's to tell the provenance of the engine.
Old May 17, 2014 | 02:30 PM
Grizzly old man's Avatar
Every few months I just pop the hood while I'm at the car wash and wash the engine bay and engine off. I do not cover anything special but I do shut the engine off so it does not suck in any water. I've been doing this since we got the car a few years back.
In the old days I always made sure I had a can of WD-40 along when I would wash the engine in my other cars. It helped dry things out if/when they would get drowned out, so far the HHR just fires right up and has no problems.
Old May 18, 2014 | 11:32 AM
I'm old, I still use the original GUNK to clean the engine bay. Don't tell anybody but over the years I read the directions, not all at one time, because of course men don't read directions. Seems to work well and I have never had a problem with it.........
Old May 18, 2014 | 02:28 PM
Problem I have found with GUNK is aluminum doesn't like it much. Fine for cast iron.
wagoneer
Maintenance and Upkeep
Jul 30, 2010 11:03 AM
jaime_g
7
Apr 12, 2009 10:03 AM
Jeff®
Sep 29, 2008 09:09 AM
MWG2
Dec 26, 2007 10:29 PM
Lone Ranger
Jun 29, 2007 09:12 PM
