Strong fuel with full tank.
Old Feb 8, 2022 | 11:34 AM
Gearhead1's Avatar
Originally Posted by Oldblue
Empty fuel tank, by running it down till the low fuel light comes on.
you can’t see up over the tank, no room.
Ok… I was hoping…lol
Old Feb 8, 2022 | 12:15 PM
To drop the tank , you’ll need a jack 4 safety stands, 2x2 foot square piece of 1/2 plywood, 15 mm socket 12” extension and a ratchet, 3/8 or 1/2 drive.
a tutorial from beanwagon
https://www.chevyhhr.net/forums/how-...acement-36541/
While the tank is down, change the in tank fuel pump, you just know it’s gonna fail after a couple of tanks of gas, why drop the tank twice?
Before you drop that tank double check the vapour and fuel lines
https://www.chevyhhr.net/forums/how-...follies-62310/
Old Feb 8, 2022 | 01:59 PM
Gearhead1's Avatar
Will do. Thanks
Old Feb 8, 2022 | 03:34 PM
I might have forgot about a screwdriver for the gas filler hose clamp, and a pair of pliers or tool for the fuel line disconnect fittings.
if its the fuel lines, you don’t need to drop the tank.
Old Feb 8, 2022 | 10:39 PM
Gearhead1's Avatar
Oh, ok. Thanks again
Old May 3, 2022 | 10:22 AM
  #26
CC Rider's Avatar
Here is another possible source of a fuel odor. Take a look at your fuel fill tube for heavy rust. My old tube had very heavy rust where this bracket was welded. With a full tank, there was a strong fuel odor at the right rear. One evening, I was lucky to spot a few drops of fuel on the driveway. When I crawled under the car and looked up, there was still a small drip of fuel hanging off the fill tube. Must be a small pinhole in the heavy rust area. My fuel odor problem is gone.
There must be a small pinhole in the rusty area.
Old May 3, 2022 | 02:33 PM
  #27
I think you’re correctly looking at a very good possibility of the rust eating that tube . I often wonder if a gas compatible hose can be used to connect those two pieces after you cut out the rusty piece.
Old May 3, 2022 | 08:44 PM
  #28
I wonder how such a bad welding job gets past QC.
Old May 3, 2022 | 10:55 PM
  #29
Pro4Art's Avatar
RTV? Silicone? Silicone is worthless for fuel leaks as the gas turns it into running goo. Silicone is a hazard to use on an engine, because excess seeps out and leaves loose "worms" that tend to fall off with time and go to the oil pump. If you use it wrong, excess comes out at all edges, AND, if its used to seal a gasket that has a hole/passage. it seeps into that hole, reducing the size. If its an oil hole, can you guess what COULD happen?
Old May 4, 2022 | 07:10 AM
  #30
Hmm the seal from the factory for the oil pan and the engine upper and lower halves is a bead of sealant, possibly RTV or room temperature vulcanizing. A form of silicone. But it’s applied in a very precise manner.
Oldblue
Mar 14, 2018 09:41 AM
guppy
Jan 18, 2018 08:01 AM
bugo
Oct 17, 2015 01:02 AM
JMichael
Oct 5, 2015 07:14 AM
SindyDix
Aug 10, 2006 12:58 PM
