Transmission Mount Needs replaced
Old Dec 17, 2017 | 11:17 AM
Ohirolina's Avatar
Safe to assume this shouldn't look like this?
Should I consider replacing any other mounts while I am at it? Vehicle has 72,000 miles. 2010 HHR Panel LS
Old Dec 17, 2017 | 11:28 AM
Cat Man HHR's Avatar
Read this:
https://www.chevyhhr.net/forums/driv...-mounts-36963/
While you at it get their engine mount also.
Old Dec 17, 2017 | 11:48 AM
There are 2 trans mounts and a motor mount, and a bracket between the trans and motor that I had crack, it was cheap <$20.
Old Dec 17, 2017 | 12:42 PM
I’d say it’s shot! May I suggest changing all three mounts as a set. I’ve read that different companies have different compounds of rubber and aren’t completely compatible!
Order one front and one rear transmission mount
RockAuto
And one upper engine mount
RockAuto
From the same company.
I myself prefer AC Delco products, however I posted the RockAuto site as an example.
Old Dec 17, 2017 | 01:34 PM
Ohirolina's Avatar
[QUOTE=Oldblue;835108]I’d say it’s shot! May I suggest changing all three mounts as a set. I’ve read that different companies have different compounds of rubber and aren’t completely compatible!
Thanks. I just placed the order for all three.
Old Dec 17, 2017 | 05:51 PM
Glad to help, I figure if I learned something could be a problem, share that information, save someone else the trouble.
Are y’all changing these yourself?
Torque valves are in the How to section
mpc3227
Jun 9, 2015 07:14 PM
bpb355
Drivetrain (Excluding Engine)
Jun 18, 2014 06:32 AM
Greg in VA
Jan 27, 2013 06:44 AM
havoc3d
21
Dec 22, 2011 04:22 AM
Zagohhr
2.4L Performance Tech
0
Sep 1, 2010 10:23 AM
