Turn signal Bulb
Old Nov 10, 2017 | 04:38 PM
The outer element is tail lights. When you step on the brake or activate the turn signal, the inner element, that is tucked behind, illuminates also. Whether it's one element burning out, or both, could be very important information.
Then again, is the bulb really burning out, or does it just not light up anymore? Did you test the "bad" bulb, or can you visually tell that it's burned out? Of course, if you've done either, you should know if one or both elements were bad.
Many, many times, folks will pick and choose which questions to answer, it usually results in a dead thread that never gets solved. Help us to help you, we can't come to your house and find the answers.
Old Nov 10, 2017 | 09:48 PM
Dennis Puskar's Avatar
2 rear turn signals ?
What is paying by the bit ?
Old Nov 10, 2017 | 10:34 PM
Yes there is one left and one right.
Paying by the bit is a reference to your extremely short answers. Bits and bytes are units of data, you seem to not be on an unlimited plan.
There, that's what answering questions looks like. If you still want some help figuring out your dilemma, you should try answering the questions that have been asked of you.
Old Nov 17, 2017 | 09:19 PM
Guess the OP ran out of bits or bytes.
LEN
Jul 18, 2015 06:20 PM
eagle914
Jan 15, 2013 11:10 AM
Old Lar
Maintenance and Upkeep
12
Mar 21, 2012 08:25 AM
trickss
Apr 5, 2011 03:40 PM
ummlee
May 15, 2009 07:33 AM
