up date
Old Oct 16, 2022 | 08:58 AM
pecrichard99's Avatar
up date
For information only-My cruise control worked only when it wanted to-I looked for a bad ground or the switch on steering wheel- I replaced the 4 bulbs in 3rd brake light and YAHOO I got cruise all the time now- Try it you will be amazed
Old Oct 16, 2022 | 10:09 AM
Pretty much ancient news. All 4 of the bulbs must work for the resistance to be right , LEDs must have "OBD2" resistors.
The computer uses the resistance of the third stop lamp to determine if it should turn the Cruise control on or off. Like when you are driving and step on the brake to turn it off.
In addition, the cruise control won't activate unless the brake pedal has been depressed. That is only possible with a standard trans that can be started in neutral.
oldracer
Nov 17, 2020 08:14 PM
Britjoe
Maintenance and Upkeep
Jul 21, 2014 08:48 AM
Radco
Mar 9, 2014 09:52 AM
myers1wa
Nov 20, 2013 10:02 AM
WEB
Sep 3, 2009 09:16 PM
