V8 HHR Build
Old Jul 30, 2021 | 06:46 PM
  #1101
Redass's Avatar
Originally Posted by sleeper
Not designed for 1/4 mile action.
Now that's a great, old school style salt runner fer sure. love it!
Old Jul 30, 2021 | 08:00 PM
  #1102
This one met with a bad crash ending.
Old Oct 20, 2021 | 10:41 AM
  #1103
lasater's Avatar
ENGINE UPDATE
Thru a series of unfortunate events my 5.7 hydroniced and bent #8 rod and cracked the cylinder. Block destroyed needed to be replaced. Decided to build a better blower motor.
Switched from aluminum to cast iron. I purchased a new GM Performance 6.0 block from my local Chevy dealer and took it to the machine shop. Texas Speed supplied the rotating assembly. 4” forged stroker crank, rods rated for 1100hp, 32cc dished Wiiseco pistons for a compression ratio of 8.6 : 1. Due to the previous motors too high compression ratio it lifted a head causing the damage. This time I went with ARP head studs and a much lower cr. Current displacement is 408 ci.
Old Oct 20, 2021 | 11:17 AM
  #1104
Yikes, that’s got hurt the wallet! How much boost was the blower set at?
Old Oct 20, 2021 | 08:22 PM
  #1105
Originally Posted by lasater
ENGINE UPDATE
Wow, seems the higher cr made the engine very unhappy. Sorry to hear, that 8-71 pumped it up. I use Wiseco pistons in Harleys, good products. That new cr of 8.6 : 1 should be much better. Better this go-round.
the ARP head studs will be a nice plus.
So stroked it will be what ci ?
Old Oct 21, 2021 | 07:53 PM
  #1106
lasater's Avatar
Yes, the bore is 4.05 and the stroker crank is 4.0.
Old Oct 21, 2021 | 08:03 PM
  #1107
That is some engine! Like jewelry! Very nice!
Old Oct 21, 2021 | 08:17 PM
  #1108
That is Sweet, & almost square B&S... Iron Block mostly used in trucks, right ? Definitely must stronger. Is that the same Blower Drive Services 8-71 ?
Wish that was going in my Panel.. (drool)..
Old Oct 21, 2021 | 09:09 PM
  #1109
lasater's Avatar
. Iron Block mostly used in trucks, right ? Definitely must stronger. Is that the same Blower Drive Services 8-71 ?..
yeah it’s an LQ9 iron block. I actually had a hard time finding a new block. My local Chevy dealer had it shipped in from Michigan.
Old Oct 21, 2021 | 09:48 PM
  #1110
lasater's Avatar
This time it’s going to be run on an engine stand before going in the car. This thing is so incredibly difficult to work on in the engine bay. Chasing things like vacuum leaks were very hard before. To this end I’m going to build a low-buck stand. And when I say low-buck I really mean it. LS engines require a specific type of return fuel system. I found out that the fuel pump from a late 90’s F150 pickup will work on an Ls. I bought a cheap Chinese eBay pump for $34 and coupled it with an eBay regulator $22 and a Home Depot 5 gal bucket……. Instant Ls fuel system.
