V8 HHR Build
Old Feb 6, 2016 | 06:45 AM
  #731
I've never Skyped so can't confirm a conference call but I will get the app a call you!
Congrats on the 2015 HHR of the year win for your LS panel!
Old Feb 6, 2016 | 07:50 AM
  #732
shouldahadaV8's Avatar
here you are ..skype conference call.
Make a Conference Call
  • Open Skype and log in with your user name and password.
  • Click the Contacts tab in the main section of your Skype window.
  • Find your friend's contact information and double-click the name.
  • Find another friend from your contacts list whom you'd like to invite to your conference call. Right-click his or her name and select "Invite to Conference" from the menu that appears.
  • Alternatively, invite multiple contacts to a conference call at the same time by clicking each contact name as you hold down the Ctrl (control) key. Once you have selected the contacts you'd like to invite, click the "Invite Selected Contacts to Conference Call" button.
  • Another way to create a conference call on Skype is to select the contacts you'd like to talk with. Hold down the Ctrl key as you click on multiple names.
  • Click "Tools" on the horizontal menu along the top of the application window.
  • Select "Create a Conference Call." Choose any additional contacts you'd like to invite via the menu that appears.
Old Feb 7, 2016 | 04:33 PM
  #733
lasater's Avatar
Moon Knoch-Offs Complete
This is a little project that has been on the bench for quite a long time. I finally got around to finishing the hock-offs. A fair amount of lathe and drill press time is required to make them but now this little piece of the puzzle is complete
Old Feb 7, 2016 | 04:36 PM
  #734
Cliff, we need pictures man! You know or it didn't happen !
Old Feb 7, 2016 | 04:45 PM
  #735
lasater's Avatar
Okay fine
Old Feb 8, 2016 | 06:41 AM
  #736
Awesome work!!! That's better! Aaahhhhh!!
Old Feb 8, 2016 | 06:58 PM
  #737
lasater's Avatar
New Instrument Panel
Well, as luck will have it, the ECM on the HHR's are can-bus. The ECM on the Camaro is Serial. What this means is the HHR instrument panel won't get an input that it can use from the Camaro ECM.
To fix this I'm building a new instrument panel with Speedhut guages. I ordered the guages today.....about 2 weeks till they send them to me.
I removed the stock cluster and made a template with it. I then cut out some 1/4" PVC sheet to fit the shape and cut 2 - 3.30" holes in it.
Then I doubled up the PVC sheet in the attachment areas.
Then I covered in in carbon fiber.
Here are the guages: 160 MPH Speedo and a Quad guage for all the esentials.
I don't need a tach 'cuse I'm using my vintage 1962 Sun tach from high school on the top of the dash.
Old Feb 8, 2016 | 07:01 PM
  #738
lasater's Avatar
Here are the guages
Speedhut Guages
Old Feb 9, 2016 | 09:02 AM
  #739
Very cool! That'll be an easy on the eyes gauge pack!
Old Feb 9, 2016 | 09:53 AM
  #740
solman98's Avatar
No tach?
