V8 HHR Build
Old Mar 4, 2016 | 06:22 PM
  #781
lasater's Avatar
Cycling Air Suspension
Many, many things going on at the same time. As I work on things, I always don't have the right part or I need to go get something that I could get after work any other day so I move on to another project on the car that I have the parts for. With this kind of thinking, I have waaaay too many open projects, but I don't want to waste a 2 hour trip to go get a part when I could get something else done.
One of the "open" projects is the air suspension. I have an AirLift 3H control system that is still in the box. Right now, I'm using Schrader valves on 1/4" plastic air line to move the suspension up and down. The Viair compressor and tank are mounted but not wired to the 3H controller. The 3H system uses height sensors on each wheel and can be controlled from any smart phone. It's a really cool system but this, like everything else will take time to install and calibrate. I did however, drop the car down to it's lowest driving point just to see how it looked.
I think this is gonna look pretty cool with the exhaust pipes coming out of the rockers in front of the wheels.
You could only drive in a straight line like this but the bottom of the front bumper is 1 1/8" off the ground and the rubber "skirt" that hangs down below clears the ground by 1/4"..............so you could clear a cigarette butt.
Old Mar 5, 2016 | 09:20 AM
  #782
That is a cool ride height control system, careful you don't hit a manhole cover!! Or a cigar butt!
Old Mar 5, 2016 | 09:37 AM
  #783
Any one else notice the reflection on the side doors ?
Makes it look like the doors are crumpled with body damage.
Old Mar 5, 2016 | 09:43 AM
  #784
Yeah, but on closer inspection, I think it is a car cover hanging up to dry .
Old Mar 5, 2016 | 11:42 AM
  #785
lasater's Avatar
You are correct. It's a car cover draped over the stair railing. Good eye.
Old Mar 5, 2016 | 07:37 PM
  #786
Radco's Avatar
Las Man I love this thread and seeing your progress, Frigging awesome job you have done :) Wish I had your skills
Old Mar 6, 2016 | 06:04 PM
  #787
lasater's Avatar
An Entire Day's Work
I wasn't satisfied with the ECU mount so I spent all day with my plasma cutter, welder, drill press and grinders making a new one. It's 14 guage hot rolled sheet. Right now it's only primer, this week I'll paint it gloss black. I ordered a nutsert installer and when it shows up I'll put a couple of 1/4 x 20 nuts in the inner fender well to mount it.
Old Mar 8, 2016 | 06:29 PM
  #788
lasater's Avatar
OK, I need your Input
The guages came in and I can't decide on which side to put the Speedo.
I'm posting 2 pics of the new cluster, one with it on the left, one on the
right. Let me know your thoughts.
Right Speedo
Left Speedo
Old Mar 8, 2016 | 06:37 PM
  #789
Kinda small pics, but then I looked at them in your gallery, full-size. I can see why it's a tough decision. Does one position make it easier to see the 4-pac of small gauges through the steering wheel?
Old Mar 8, 2016 | 07:26 PM
  #790
RF2's Avatar
RF2
Left hand on steering wheel, right hand shifting. What ever you put on the left side might be covered up by your arm.
