V8 HHR Build
Old Mar 10, 2016 | 02:27 PM
  #801
lasater's Avatar
Originally Posted by whopper
I'd leave out the tach - just run ér till either the valves float, or the rev-limiter kicks in.
What Rev Limiter?????
Old Mar 10, 2016 | 02:44 PM
  #802
celblazer's Avatar
That loud boom usually works really well as a rev limiter ONCE. :)
Old Mar 12, 2016 | 09:34 PM
  #803
lasater's Avatar
Bit by Bit
Man, there are so many things to do on this build. Everywhere I look there is something that isn't done or needs to be re-done. I think I finally have the rear axle and the suspension correct and the airbag clearance problems fixed. The Ls ECU is mounted and next I mount the main fuse/relay block. A bunch of components got moved around because I thought the air intake would fit on the passenger side but it won't........so it's back to the driver's side as it originally was. I don't know what's up with the wiring yet, that's an ongoing challenge. Here is what it looks like today.
Old Mar 13, 2016 | 10:22 AM
  #804
A little crowded in that stable of ponies!! But once you fire it up and close the hood, all will be good!
Old Mar 13, 2016 | 10:09 PM
  #805
lasater's Avatar
Almost done with the main fuse/relay box mounting bracket. It's a surprisingly large amount of work to adapt the plastic components to a bolt-in metal bracket. Here is what I have so far.
Old Mar 14, 2016 | 07:56 AM
  #806
Are you going to put the driver monitor "black box" from the 'vette under the seat?
Old Mar 14, 2016 | 10:40 AM
  #807
lasater's Avatar
What "driver monitor"? I'm using the HHR BCM in its original location, the HHR main fuse/relay block under the hood and the Ls1 ECU under the hood. That's all I'm aware of.
Old Mar 20, 2016 | 08:59 PM
  #808
lasater's Avatar
Tiny projects
My time seems to get taken up with he smallest of projects. I finally got the fuse block mounted properly, the cover still removes just as stock......only sideways. The battery + cable is run to the fuse block and the starter cable is run from the fuse block to the starter motor. I need to get some crimp lugs for the cable and secure the starter cable away from the headers. I'm also working on a support from the front of the drivers side coil pack mount to underneath the MAF on the 4" air intake. I'm having a hard time getting the twist in the support just right. I'll keep plodding along.
Old Mar 21, 2016 | 01:54 PM
  #809
Your attention to detail is quite amazing!
Old Mar 21, 2016 | 02:44 PM
  #810
lasater's Avatar
Thanks for the compliment, but I really don't have much of a choice. Once you commit to a build like this, you are competing with some amazing vehicles. I passed the "Budget RWD / V8 conversion" long ago. Even your local cruise night has cars that only a decade ago would have been impossible to build. The level of craftsmanship and technology has evolved to incredible levels.
And besides, the first cruise night I lope into, I plan on blowing them away.
