V8 HHR Build
Old Mar 12, 2017 | 11:24 AM
  #981
What side windows, it's a panel!
Hey Cliff are y'all sure you don't need bigger brakes?
Ecotec Parts ZZP 14.5 inch Front Brake Kit
I know you have the 'vette brakes but are they up to the task??
Old Mar 12, 2017 | 01:06 PM
  #982
lasater's Avatar
The 'Vette C5 front brakes will be working in conjunction with the Wilwood 4 piston units that are required on the 9" rear. I think I'll be OK.
Old Mar 12, 2017 | 01:33 PM
  #983
Well if not, I still have my old brakes from my drag car!
I only had it in case of emergency!
Old Mar 14, 2017 | 05:52 AM
  #984
Fox Hat's Avatar
Old Mar 14, 2017 | 04:51 PM
  #985
Cat Man HHR's Avatar
Cliff tell the truth. Are you into oil, gold or diamonds to pay for this build? Or maybe you own like 100 7/11's?
Old Mar 14, 2017 | 10:38 PM
  #986
lasater's Avatar
All of the above
Old Mar 15, 2017 | 06:59 AM
  #987
aradmahogany's Avatar
It wouldn't be considered a true project car unless it was expensive! Besides what he is building here is priceless. I wanna see a Drag Race between this thing and the other v8 build when it's all done! (shouldahadav8 I think)
Old Mar 19, 2017 | 11:40 AM
  #988
lasater's Avatar
Nitrous Install
The nitrous solenoids are installed and plumbing continues. The 15lb nitrous bottle rack sits on the top of the box that is in the rear seat area, over the air tank and battery. The nitrous master arm switch and purge button mount in the rear of the B&M shifter base. I'm starting off with "baby" 75 hp nozzles at first. No need to go nuts. The windshield squirter nozzles are being replaced with the purge lines to spray straight up in front of the windshield.
Old Mar 19, 2017 | 11:52 AM
  #989
Awesome work, back in the day ,we would just say, sanitary!
Old Mar 19, 2017 | 02:35 PM
  #990
Frenchy42's Avatar
So, looking through the other thread on this and the beginnings of this one, this was initially supposed to be just a stock LS1 going in a rear drive HHR. I know a lot of the custom stuff would still need a lot of work, but do you think you would be done by now if you hadn't decided to beef up a few things? Or do you think you'd still be working on it?
