Washing the car
Old Jun 10, 2018 | 08:50 PM
Ron S's Avatar
Cat Man why is that stupid?
Old Jun 10, 2018 | 09:00 PM
I think he was referring to not buying the towels when he walked by them.
My understanding, for a wash that you don't have to dry, you would want reverse osmosis with a large tank at your wash station.
Old Jun 10, 2018 | 09:23 PM
Ron S's Avatar
I have had good luck with that method, it seems to work as well as a chamois and much easer to clean. It breaks the surface tension of the water droplets and leaves the surface slightly damp and I don't get water spots. I was going to ask him if he knew how to tune a 3 cylinder 2 cycle Saab. You set the timing by the center cylinder. When I had British cars I could pull both side draft SU's rebuild them, reinstall both, tune and synchronize them and drink a beer in an hour. The one thing about early British sports cars, the had two fuses, one for the left side and one for the right. The fuse block had two extra holes for two spares. Fun cas
Old Jun 10, 2018 | 09:43 PM
Originally Posted by Ron S
To wash ours I use a "Foam Canon", it hooks on the end of my power washer head and puts a layer of soap foam over the car, I use Maguire soap, then a I use the power washer with a spread nozzle to spray the cars off. It works well. There are some YouTube videos of it in use. Neat gadget. My power washer is electric.
My neighbor just got one of those foam cannons. He is always trying the latest stuff. He likes it.
Old Jun 10, 2018 | 10:50 PM
I should add that you wash and rinse with your regular water, (keeping the car wet)then when you're done, do a final rinse with the RO water.
The Mr clean device was pretty good.
Old Jun 11, 2018 | 10:45 AM
aradmahogany's Avatar
Originally Posted by donbrew
Be careful with power washers if your car has pin stripes!
Gregg has LOTS of vinyl on him, and they are unaffected from my power washer!!!
Old Jun 11, 2018 | 11:35 AM
Mine is getting washed right now... It's raining.
Old Jun 11, 2018 | 08:52 PM
Mine will be getting washed tomorrow, as I'm out & about in the 'predicted' rains.
Old Jun 13, 2018 | 12:35 PM
Cat Man HHR's Avatar
It means how simple your way of doing it and I never thought of it. No reflection on you at all.
Old Jun 13, 2018 | 12:38 PM
Part A: Your correct
Part B: Do I wish I had a system like that at home. That's why I am using an inline RV water filter on my hose to see if I get "cleaner" water to rinse off the car.
ultramicrofiber
Maintenance and Upkeep
88
Jan 3, 2022 10:59 AM
mchuntley
36
May 6, 2011 05:13 PM
karen1953
20
Aug 30, 2007 03:44 PM
calgaryhhr
May 12, 2007 05:49 PM
batman5273
Apr 28, 2006 01:34 PM
