2.0 question
Old Jul 13, 2020 | 08:59 AM
According to the poster in the link that I provided, the LDK and LHU do not have sleeves. Do your research, trust but verify.
Old Jul 13, 2020 | 09:26 AM
Hmm. I wonder if that's true. Aren't the LDK's and, LHU's aluminum blocks ? If so, then wouldn't they need to have sleeves ?
Just thinking..............
Old Jul 13, 2020 | 10:30 AM
LDK info based on LNF
https://zzperformance.com/products/ldk-long-block
LNF has sleeves, therefore tge LDK has the same
https://zzperformance.com/products/g...nf-short-block
how’s that for verification, trust me, I’ve done my research
Old Jul 13, 2020 | 11:59 AM
Really doesn't prove anything, sleeves aren't mentioned on their LHU page. ZZP is referring to these as "gen 3", but wiki says that they are gen 2.
https://forum.hptuners.com/showthrea...-disable/page2
Same poster, seems to know what he's talking about.
*note: if you have a Gen I LNF motor it will have bore sleeves. you cannot bore these as they will crack and cause massive internal damage. The new Gen II LDK/LHU block has solid bores and many other upgrades. Unfortunately lsj heads cannot be swapped onto them so you will have to use direct injection on these blocks. from aftermath chatter of boosted le5 and lsj's i believe the le5 has a not so strong block casting and will likely crack sooner under high boost (30+ psi) when compared to the lsj.
i have the build book which is cool but almost half the stuff they list for upgrades doesn't exist any more or has been further upgraded by many other companies. still a good reference book, i kept mine.
He seems to be the only person on the internet that is even talking about the makeup of these cylinder walls.
Maybe someone has a shop manual for the LHU, can clear up whether they can be bored, or if they are sleeved.
Old Jul 13, 2020 | 12:31 PM
LHU are based based on Gen 3 block
https://zzperformance.com/products/z...ng-short-block
you can see the lines around the sleeves
https://zzperformance.com/products/g...sj-short-block
a how to about removing and pressing sleeves
https://dartonsleeves.com/pdf/Ecotec_Manual.pdf
Old Jul 13, 2020 | 01:37 PM
Cat Man HHR's Avatar
Again I say, no visible damage to the bore, then ball hone it.
Put new rings on the pistons and move on with the rebuild.
Old Jul 13, 2020 | 03:10 PM
From https://zzperformance.com/products/g...sj-short-block
-Cylinder wall bracing that prevents sleeves from breaking out in high HP applications
From https://dartonsleeves.com/pdf/Ecotec_Manual.pdf
[QUOTE]Caution must be exercised as old sleeves are bored out to prevent tearing of aluminum in block and possible tool breakage; original sleeves are ribbed and cast in place[/QUOTE]
Old Jul 13, 2020 | 03:59 PM
Same link I posted.and
Details of the new LHU block: http://www.gmpowertrain.com/Powertra...0turbo_v2.docx
or this link: https://www.dropbox.com/s/ei12w4hses...20turbo_v2.pdf
"...The main bearing bulkheads, which support the crank bearings, as well as the cylinder borewalls have been significantly strengthened to support increased engine loads. Refinements to the oil distribution system enable improved oil flow throughout the engine and an expansion of the coolant jacket, along with the use of cast-in-place bore liners, allows more precise boreroundness and improves the block’s ability to dissipate heat."
That explains.
Lots of differences to the LSJ/LNF block (oil pump, balance shafts, crank bearing dimensions, reversed head etc.) so not sure if this is swappable with and LSJ/LNF head.
from this link
https://www.cobaltss.net/forums/www....age=2&t=289219
Old Jul 13, 2020 | 04:07 PM
I guess I don't care enough to keep researching it. I can see that the 2 blocks you've linked to at ZZP are very different. I've read that the LHU is not exactly sleeved, but has a sprayed on liner. Nickel or something is the name of it, spelled differently. But still expensive if you damage it.
Old Jul 13, 2020 | 04:09 PM
Same results, the block is scrap if the bore is damaged or worn to far out.
drummerboy0088
Jul 21, 2020 08:32 AM
Dbeluscak
Jun 1, 2015 05:12 PM
Shaggyofwv
2.0L Performance Tech
Jan 5, 2014 06:56 PM
JAXFL_SS
0
Jun 25, 2013 07:47 PM
Bkm0607
0
Aug 5, 2012 06:30 PM
