Another Brembo question
Old Oct 23, 2023 | 04:28 PM
Shims ? My SS with Brembo’s didn’t have shims.
Old Oct 23, 2023 | 04:56 PM
Uncle Moe's Avatar
Hey George thanks for the reply, did your SS come with Brembos? Cuz apparently when u upgrade from stock SS calipers you buy the new larger rotor but there is supposed to be a shim that goes on The hub before you put the rotor on because when you bolt up the Brembo caliper it isn't directly centered over the rotor it's off to one side just enough to give you uneven pad wear...
EDIT.. apparently its been called a hub or bearing spacer and i was wrong, it goes on before the bearing? Something to do with the thicker bearings?
RBodeman
Oct 31, 2022 08:43 AM
gmdealerguy
Jun 26, 2022 09:24 AM
Shane H
May 28, 2015 03:43 PM
AJL08SS
Dec 16, 2013 03:11 PM
Red Rocket SS
Dec 10, 2012 12:37 PM
