Door Lock Issue
Old Mar 21, 2021 | 10:18 AM
A squirt of spray lubricant might resolve that gummed up linkage
Old Mar 22, 2021 | 09:01 AM
ibenzawla's Avatar
Originally Posted by donbrew
The actuator is part of the latch. If you get a new cylinder you will want to get a locksmith to match it up to your key.
I'm thinking the latch/rods are sticky.
Thanks a lot. I may have to replace both.
Old Mar 22, 2021 | 09:03 AM
ibenzawla's Avatar
I may have to start with that before replacing since it works most of the time. Thanks.
Old Jun 2, 2021 | 12:32 AM
ibenzawla's Avatar
Yes I finally applied some WD40 and the lock movement is much more smooth. No resistance when turning the key. Finally able to lock the car. Still have the remote key fob issue but will leave with that.
Old Jun 9, 2021 | 07:44 AM
FreddyPayne's Avatar
Why don't you change the battery of the remote fob, i am sure it will work after replacement. xxxxxxx has suggested me this idea when i am having issues with remote fobs.
Old Jun 9, 2021 | 10:20 AM
Guess you didn't read the thread. The part where he got a new remote and got a new battery but still had issues.
Old Jun 11, 2021 | 12:59 PM
PulpFriction's Avatar
You should check if the fob locks and unlocks the hatch, even when it doesn’t work for the doors. It’s on a different circuit. I was having trouble with the door locks in my 2008, even when I pulled the door locks fuse, the hatch still worked with the remote. Checking that might provide some insight as to what’s going on.
Old Nov 8, 2021 | 03:54 PM
JEHantqs's Avatar
Angry HHR 2010 Keeps Locking By Itself
Hi 2010 HHR L2 with less than 60 k and doors have locked twice now in less than one week with KEYS IN IGNITION while I was in getting coffee Any suggestions other than taking my keys with me which in over 60 years I have never done !
Old Nov 8, 2021 | 04:26 PM
Head to the auto parts store for a free battery load test.
You could remove the fob and keep it in your pocket, leaving the key in the ignition(for whoever comes along).
Old Nov 8, 2021 | 05:22 PM
JEHantqs's Avatar
:) Thank u. ? free battery load test ? I have decided to get two new keys made , one for my wallet and one for my other back pocket :) Thank you
