hhr ss help
ssdivin - did you get it running yet? Or is this preventing it from running?
Check anyway on yours if you get a chance. Just to make sure. GM would have had to use two different solenoids for the ports to be different, but I guess it's a possibility.
Check anyway on yours if you get a chance. Just to make sure. GM would have had to use two different solenoids for the ports to be different, but I guess it's a possibility.[/QUOTE]
I was just going off of memory. the top one is where i put the T in place when i had the BOV and BPV before my block off plate
