2009 hhr
You just need to use the HHR LS/LT caliper brackets & rotors, if you have the standard HHR SS brakes.
Easy-peasy as you don't have to disconnect the brake lines.
14-1163 & 14-1164 brackets on rockauto for $25 each
22705303 & 22705304 from GM for $65 each.
Centric rotors for $30 each
$120 total to run 15" wheels on the front with new rotors & reman brackets.
A lot cheaper if you go to the bone-yard or craigslist.....
And correct, you can't use 'Brembos' as they are way too big.
Spoon
07-08-2013 02:15 PM
