normal boost VAC/press
Old May 25, 2014 | 09:20 AM
Cokeybill's Avatar
Not exactly correct. Those numbers are a little high but "may" be obtained under the right conditions: vehicle, altitude, air quality, etc.
Mine at around sea level will hit about 19-20 w/GMTU on normal days. On some crappy air days, it may peak at 21.
(and yes mine is running correctly. No boost leaks and hitting full power by the RPD readings)
Like the tech from GM's performance division told me. In a nutshell, "It will put out the amount of boost needed to obtain the power levels required by the ECM and the torque management programming."
Your peak levels aren't even near mine when I originally had the GMTU installed. I can and have on a consistent basis hit 23. I have nothing to prove, just stating my true stats. too bad you need to tell others of your poor stats. I chatted with Bill (the GMPP developer of the tune way back in 08 and he told me that that was consistent numbers with the Stage 1 at the time. He also told me the ECM would learn down if the vehicle was not driven to performance. Now what?
Old May 25, 2014 | 09:52 AM
Well I guess you're right and everyone else is wrong.
Fwiw. The guy I talked to was named Bill. He told me my boost numbers were fine as long as I was making the hp/torque. I've been hitting that 19-20 since day 1 of the install. Learn down, I think not in my car since it's stayed the same.
Quote:"too bad you need to tell others of your poor stats."
Not even gonna go there. My SS is perfectly fine and runs well.
Old May 25, 2014 | 10:29 AM
Cokeybill's Avatar
Good for you. Hope you find what you need. I don't need to.
Old May 27, 2014 | 06:11 PM
Gee, you think "North" might have a different baro than Alabama?
I don't understand "Hope you find what you need. I don't need to." in this context, did I miss a pissing contest somewhere?
Old May 27, 2014 | 06:48 PM
Plus donbrew, I'm at "sea level Alabama", so yes it would be different than anyone who's at any elevation.
Pissing contest? Not here. Just trying to keep some false info from being posted that EVERYONE should have 23 lbs of boost or more. Just isn't true.
chevymanls6454
Sep 10, 2014 05:49 PM
XtremeSS
2.0L Performance Tech
13
Mar 8, 2010 10:48 PM
ouhockeyplayer
Dec 11, 2009 07:29 PM
Sandhog
Feb 25, 2009 12:14 AM
twistedamd
Jul 8, 2008 09:08 PM
