Problems with the SS
Old Aug 7, 2009 | 02:47 PM
JeramieJJ's Avatar
Originally Posted by BowTieBob
Well, I finally got the SS back the other day. It has a new turbo, and all new piping. seems to be running good so far. Hopefully it keeps running good. The plastic piping they put on these things is junk.
Glad to hear your back on the road. Did it take a month or so for the turbo arrive?
I'm in the same boat, my expected replacement turbo should arrive Aug 20th from overseas.
Old Aug 7, 2009 | 02:50 PM
vwkyote's Avatar
I'm personally worried about parts for the SS's. Mine needed the fuse block replaced because of a bent pin in manufacturing, and it took 2 weeks for the part from the States into Canada. I was stuck with an Impala rental...
Are SS parts harder to source???
Old Aug 8, 2009 | 05:07 AM
BowTieBob's Avatar
Most of the time was waiting for parts. It needed a turbo actuator and there were none in the country. It took about two weeks to get the part and they sent an entire turbo unit just for the actuator. When the actuator didn't fix it, GM told them to replace the turbo. Replacing the turbo didn't fix it either. They finally replaced the lower pipe from the intercooler to the intake(several times) and that fixed it. A couple of the new pipes that they received had holes in them. Get the number for GM customer service from your dealer and start a case number with them. They can help expedite the parts.
Old Aug 8, 2009 | 05:41 PM
mightymouse's Avatar
same problem i had a little over a year ago. i tiold them they would have to pull a pipe from one off the lot or give me a cobalt ss/tc!!! my car had that problem from the day i picked it up!!! if you don't do any upgrades,i highly suggest a piping kit from one of the vendors on the site.
Old Aug 8, 2009 | 05:59 PM
gcsd3742's Avatar
There you have it.. another local guy having the same issue. GM can take their warranty and shove it somewhere....Thats why I am doing my own thing
Old Aug 8, 2009 | 07:07 PM
hyperv6's Avatar
You had three seperate issues.
One The GM Chapter 11 has made some parts on all GM cars a little slow in coming in since some vendors were charging COD. This should be clearing up and parts availability should get back to normal soon,
Two The part you neeed is the same one my dealer needed. It has no part number at this time and thows dealers an curve in trying to order these. Hard to order a part with no number in a system that requires numbers.
Three I assume being in Canada just slowed it down even more on top of the no part number issue.
In the future parts should not be an issue and things should improve. It is not just a HHR thing.
Dharkons
Nov 29, 2017 04:42 AM
06chevyHHR
Jan 22, 2013 05:55 AM
SmootHHR
May 22, 2011 04:38 PM
HHR4JK
Apr 9, 2010 06:48 AM
SPPD
Jul 16, 2008 01:22 PM
