Service Air Bag
Old Apr 19, 2019 | 12:59 PM
mblandsr's Avatar
Service Air Bag
I have a 2010 HHR SS 5spd. On starting I get a Service Air Bag Message. If I restart the message goes away, does anyone know about this? My car has 37,000 mile on it.
Old Apr 19, 2019 | 01:44 PM
You will need a sophisticated code reader while the light is on. It could be anything, maybe a failing battery.
Old Apr 19, 2019 | 09:52 PM
J W Davis's Avatar
Wink
Last time I saw that message it was a loose wire in a connector under the passenger seat. Victim of "aggressive Vacuuming again".
Old Apr 19, 2019 | 11:21 PM
I suggest the battery because it happens on the initial start (battery drained from sitting then starter draw) then does not on restart (alternator has refreshed battery a bit).
The SDM needs at least 9 volts to operate.
Old Apr 20, 2019 | 10:34 AM
There was a recall on my 09 SS, for an airbag system connector. Are you current on all recalls?
Old Apr 20, 2019 | 12:08 PM
mblandsr's Avatar
Thanks to all for the information
Thank everyone for the quick response. I will check things on Monday. Again THANKS......
Mike
Old Apr 20, 2019 | 12:24 PM
There is a TSB about corrosion. A reader that reads SIRS codes can tell which connector has a problem; you need the Bxxxx code plus the descriptor (the 2 digits after that).
Old Apr 20, 2019 | 12:36 PM
Was that the connection behind the passengers outside footwell panel?
Old Apr 20, 2019 | 12:38 PM
Yes
Old Apr 20, 2019 | 12:57 PM
ahh, here is a link to one members struggle to resolve his airbag warning issues - https://www.chevyhhr.net/forums/prob...d-57513/page2/
radcon
Jun 5, 2012 01:38 PM
zbear
Jan 26, 2012 04:58 AM
MetallicaMatt
15
Mar 20, 2011 10:00 PM
diskullman
Jul 28, 2010 09:57 AM
TyroneMD
Dec 17, 2009 02:20 PM
