Steering position sensor
Old Nov 10, 2024 | 11:00 AM
Pretty sure the traction control light is the key to this, that would be the wheel bearing hub speed sensors unplugged or loose, possibly a bent pin. This could be the problem.
Old Nov 10, 2024 | 11:10 AM
Unless the car has been in a collision, you don't need to replace the sway bar. It doesn't have boots. There are bushings that should be replaced as needed.
The grinding starter is a separate problem from sway bar, steering, or brakes.
Try http://Car-part.com for used parts.
Old Nov 10, 2024 | 11:19 AM
Ask what the code number is!
Eric Overmiller
May 18, 2025 02:17 PM
adam08ss
7
Mar 3, 2022 09:39 AM
RunswScissors
Feb 19, 2022 08:02 AM
mamerc
Oct 31, 2019 11:06 AM
jmule
May 29, 2016 12:19 AM
