Tie rod ends for SS
Old Feb 5, 2021 | 10:31 AM
galtjunk's Avatar
Tie rod ends for SS
2009 HHR SS Automatic with the turbo upgrade.
75,000 miles..
I replaced the lower control arms with the gm fe5 parts.
They were used up.
The alignment people told me I needed new inner and outer tie rod ends.
I went to the rock auto site and see a multitude of available parts.
Outers run from $5 to $40.
Inners run from $6 to $32,
Do I need to us genuine GM parts for these?
Is AC/Delco the same as GM?
I don't mind paying for quality.
Do these parts need an FE5 rating.
What parts do you recommend?
Should I look at replacing anything else while I am under there?
Old Feb 5, 2021 | 10:44 AM
AC Delco is fine, and yes they should be FE5, there might be a difference in threads or the tie rod nub and the taper of it.
Just like the LCA’s and specific ball joints.
You might want to consider a new steering rack if the tie rods are that beat up! The AC Delco 25956914 includes the inner and outer tie rods plus you get that tight new steering feel
https://www.rockauto.com/en/catalog/...nd+pinion,7388
but it’s up to you.
Old Feb 6, 2021 | 12:09 PM
galtjunk's Avatar
Thank you.
I ordered the rack and pinion unit from Rockauto.
Does anyone know what the installation hour on that install would be?
Old Feb 6, 2021 | 02:09 PM
When I swapped out the rack in Oldblue, an LS but the same number of fasteners, I took me 2 1/2 to 3 hours, stopping every 1/2 for a 5 minute break.
You can do this at home with a few tools the rack will come out the drivers side, I have a how to here somewhere
ah, here it is
https://www.chevyhhr.net/forums/how-...ng-rack-58948/
Old Feb 8, 2021 | 09:09 AM
galtjunk's Avatar
Thanks again.
fastsuv
Jun 23, 2020 12:24 PM
Lethal Tendencies
Sep 2, 2019 08:34 AM
BBHHR
14
Mar 22, 2019 04:50 PM
scot6580
58
Mar 24, 2017 10:24 PM
drummerboy0088
Apr 15, 2016 12:49 PM
