Top speed w/stage 1
Old Apr 21, 2011 | 11:26 AM
No matter what you got under the hood..... It can't go faster than a cops radio.
Old Apr 21, 2011 | 11:54 AM
gcsd3742's Avatar
JUST FYI FOOD FOR THOUGHT NOT ALL VEHICLES ARE THE SAME SO ANY DEFINITIVE ANSWER YOU GET ALL CARS ARE NOT EQUAL......YOU CAN HAVE 2 IDENTICAL VEHICALS AND THEY WILL BOTH BE DIFFERENT.....There's your sign.,....DEE DEE DEE
Old Apr 21, 2011 | 11:55 AM
bartSS's Avatar
Troof. My buddy outran a helicopter on his bike until he ran out of gas. Then spent a good amount of time in jail
Old Apr 21, 2011 | 12:04 PM
1Panel2NV's Avatar
If nothing physically stops you from hitting 155, you won't be going any faster...
Old Apr 21, 2011 | 12:16 PM
155 in neutral????
Steep hill !
Old Apr 21, 2011 | 12:28 PM
  #26
gcsd3742's Avatar
It could happen.. You never know, These damn SS's are cantankerous and finiky
Old Apr 21, 2011 | 01:05 PM
  #27
asanti's Avatar
Lmao, that there's an epic Fail! Your buddy's cell name should be "Capt. Failboat".
Old Apr 21, 2011 | 02:50 PM
  #28
bartSS's Avatar
He had a full tank when it all started man. In bufu wisco. I didnt know they even had copters. He lost the normal cars without a problem
Old Apr 21, 2011 | 04:22 PM
  #29
Father Azmodius's Avatar
I have always made out better by stopping on the bike. The PoPo is so surprised that I don't run, they let me go with a warning.
Last edited by Father Azmodius; Apr 21, 2011 at 04:25 PM. Reason: Spelling brain fart
Old Apr 22, 2011 | 02:11 AM
  #30
IgottaWoody's Avatar
Originally Posted by jonboyb
Are you certain the 155 is due to gearing??? I've had mine well over 140 with quite a bit of tach left so I assumed the 155 is computer controlled???
Edit: Just ran a couple calculators using a 4.05 axle and 0.70 5th gear and it shows 190'ish at 7000 rpm.....Not sure if the 0.70 5th gear ratio is right though. Anyways.....155 not due to our gears:) And the way mine pulled to 140+.....I don't think it's drag either...LOL. And on another note (as someone also mentioned earlier) the SS is rediculously smooth at high speed.
After a certain point..you have to have the power to push it..my truck does 135 tachin at 4500...and wont go any faster.. and I dont have a govenor...and that was a 5,7(and 5000lbs)....we only have a 2.0.
