Well my first problem with the SS.
If anyone is still having problems with their tire pressures not reading correctly or only have a --- (dashes) readout there is a reprogram of updated software to fix this. Other symptons might be that you are unable to achieve a reprogram by letting some air out of the tire as described in the owners manual. Another sympton might be remotes inop at times.
Be sure and take all your remotes in with you since the reprogram wipes them out and they have to all be programmed at the same time.
The TSB # is 08-03-16-001A
06gray2ltHHR
2.4L Performance Tech
08-01-2009 10:45 PM
Black Rose
12-07-2007 11:28 AM
