Do It yourself factory Fogs
I've been away for awhile and noticed the pictures are no longer valid. And my old PC died. The host server I used is no longer running. I finally got around to recovering the pictures off my old hard drive and was going to fix the pictures but I don't have edit access (might be because it several years old).
Moderator: If you can grant edit access to the orginal post or I could e-mail the pictures to you.
However: Upload the images to our gallery and I can make the changes for you.
When you upload them, keep the file name the same as they were and that will make the edits much easier for me to do.
So any one who has done this mod or mess with the fuse box have any problems electrically after?????
I was just check it out and trying to see how to take it apart, now my rear wiper runs when the switch isn;t on(cant turn it off), the rear defrost is on (can't turn it off), my ac don't work(can't turn it on). My front wipers came on half way and then stoped my lights nd signals don't work. And when i mess with the switch for the rear wiper it kills the car and turns off.
Any one happen to know whats going on? I did not even connect anything or splice power from the fuse box.
Hello all,
I am picking up a very, very nice '08 red LT panel tonight, (actually I've been driving it), but have to finish the paperwork. Anyway, when you order the factory switch for this install, does it replace the complete insert, or how is it installed? Thanks in advance!
Marty
Marty
For those of you who are still interested in doing this install yourself I thought I would pass on information of where I got the OEM replacement fog lights.
I purchased these lights from Auto Accessories Warehouse:
http://stores.channeladvisor.com/aut...sorywarehouse/
The lights were $48.58 each with free shipping and handling. I had to call the company, though, as the free shipping was not showing up when I went through the checkout, but they took care of it immediately. Shipping took only a few days from California to the Midwest.
The lights are made by TYC, and are marked as OEM replacements for part number 15813308 and 15813307. They are very nice lights, fit perfect, and have the up and down adjuster.
Now all I have to do is get the BCM programmed for the lights and I am good to go.
