Do It yourself factory Fogs
Old Mar 9, 2018 | 07:30 PM
  #121
mercury2005's Avatar
Just read this thread and have a question on the location of the BCM. Is it located behind the passenger kick panel and if so when I go to the scrap yard should I just take everything from that side, i.e., all the wiring?
Old Mar 9, 2018 | 08:44 PM
  #122
There is a good pic of it in #111.
Why are you replacing it?
Old Mar 9, 2018 | 08:53 PM
  #123
Bcm
@donbrew,
In another thread we discussed why my radio was going on-off-on-off and one answer was the BCM.
So when I go to the salvage yard I can pick up that module
Old Mar 9, 2018 | 08:56 PM
  #124
Needs to be programmed by GM.
Old Mar 9, 2018 | 09:09 PM
  #125
Bcm
donbrew,
I appreciate your help.
If I am experiencing the radio on-off problem, will just a re-program of the BCM fix the problem or will I need a new one?
Also I will be installing factory fogs, have the fogs, bought a new waterfall and fog switch, my truck already has the wiring/connector for the fogs behind the radio, so do I stil need an LT BCM or again will a re-program fix the radio issue AND let the fogs work?
Old Mar 9, 2018 | 10:25 PM
  #126
I seriously doubt the BCM is your problem.
After market, self installed radio equipment is a problem.
The BCM needs to be programmed for the fog lights, if you go that route. Pretty sure that is covered in the previous 12 pages.
Old Jun 9, 2019 | 05:08 PM
  #127
CaptainW's Avatar
CJUETTEN... Hats off to you my friend. Your diagrams got my fogs up and running as factory intended. My cr had fuse & relay installed, but NOTHING else. Add fitory switch, installed fog lights form hellshotrod, and wired in as shown on your diagrams. The case split of fuse panel was a little touchy, but after a few attempts, all was working. Thanks!!!
Putter
15
Mar 9, 2018 07:18 PM
Smoothe~ride
Apr 12, 2011 05:31 AM
ufvj217
Oct 4, 2010 01:55 PM
ufvj217
Mar 23, 2010 11:45 PM
RUDEINC
Sep 22, 2006 10:23 AM
