Fuel line follies!
Old Oct 4, 2019 | 07:42 AM
Thanks Whopper, great idea.
Old Oct 19, 2019 | 01:49 PM
This vapour line connection looked ugly and leaked air, so I went to local pick a part and cut the line way down by the steel line , lotsa tubing to have to measure better
This is the new to me tube and fitting from a sadly wrecked HHR.
The connection union is fully engaged and seated and not under any stress from the tube bending an inch or two from the EVAP valve. The P0455 code is no longer popping up since I did this , last Friday.
Old Oct 27, 2019 | 11:27 AM
Den Matlack's Avatar
This the first time on the site just can not get the line to disconnect from the fuel line back by the rear wheels, I have tried everything to disconnect pressure line connection to the pipe that goes over the fuel tank to the fuel pump. Tried those sleeves to separate the lines no luck any help would help
Old Oct 27, 2019 | 11:38 AM
The pressure line, squeeze the sides of the D shaped fitting and wiggle it off the metal line, squirt some WD40 or PB blaster on it to lubricate the oring
Old Oct 27, 2019 | 11:56 AM
no luck still locked on
Old Oct 27, 2019 | 11:57 AM
  #26
I would ask you to stop by but you are in Canada
Old Oct 27, 2019 | 12:36 PM
  #27
Just got home from our annual trip to Cape Cod, but what part of PA are you? You need just slip lock pliers to squeeze it.
Old Oct 27, 2019 | 03:16 PM
  #28
Horsham Pa tied everything still will not come apart gave up soaked it up with WD40 and watch the Eagles game now back to work on it
Old Oct 27, 2019 | 03:47 PM
  #29
<img src="https://cimg8.ibsrv.net/gimg/www.chevyhhr.net-vbulletin/2000x1504/ea83e568_35bb_4135_b499_9bec5ae50898_106573998628b 262f595a7c17b4aa18389524fd9.jpeg" alt="" />
your picture is the one Iam having trouble getting apart bfor two days
Old Oct 27, 2019 | 03:49 PM
  #30
the tool will not go all the way in to release the connection
