Fuel line follies!
Old Oct 28, 2019 | 05:49 PM
  #31
You don’t use the 3/8 tool, you squeeze the two sides of the plastic coupler, round side up , flat side down, with a pair of pliers, then gently wiggle the plastic coupler and pull the metal bundy out of the plastic fitting.
Your right the tool will not release the locking plastic spring .
Best picture, I could find, squeeze them sides not the round and flat , the green part will open up and unlock the bundy.
Old Oct 28, 2019 | 07:16 PM
  #32
Den Matlack's Avatar
thanks will try tomorrow have to be in work at 6am get up at 430am again thanks for getting back to me went to the Chevy dealer and they told me to use that 3/8 tool.
. What do they know
Old Oct 28, 2019 | 09:29 PM
  #33
Tools , same wild goose chase they sent me on.
Old Oct 29, 2019 | 09:48 AM
  #34
well I reached my limit tried everything even your idea still will not come a part taking a break for a while because I'am really frustrated
Old Oct 29, 2019 | 12:53 PM
  #35
just looked at it one more time decided to cut the line at the connection and use 3/8 fuel line and clamps thanks for all your help
Old Oct 29, 2019 | 04:01 PM
  #36
You’re welcome, sorry it didn’t work for you
Old Oct 29, 2019 | 08:58 PM
  #37
Good luck with the hose & clamps. I'm sure you know that is a hi-pressure line.
Old Oct 30, 2019 | 03:44 PM
  #38
If you cut the OEM steel line and the new steel line , you should use a compression union to mate the two steel lines together.
Old Oct 30, 2019 | 08:48 PM
  #39
Yep, agreed.
Old Oct 30, 2019 | 09:04 PM
  #40
let you know tomorrow whatI hope to do thanks for the advice I have a trick up my sleeve and these lines are the nylon like Old Blue used
