Fuel line follies!
Old 11-03-2022 | 04:57 PM
  #81
You are misinformed. The TPM sensors are inside the tires attached to the valve stems. The receiver is under the headliner near the mirror.
There are wheel speed sensors in the hubs, they get wet whenever it rains.
Old 11-03-2022 | 05:06 PM
  #82
Cheap Guy's Avatar
Gotcha. If it comes on again I’ll just swap the tires to see if it comes on for the passenger side. The tire place said the TPS was ok.
Old 11-03-2022 | 05:22 PM
  #83
Have you ever reset the TPM positions in the DIC? 2010 needs a special tool, most tire stores are clueless.
Old 11-03-2022 | 05:52 PM
  #84
The procedure to relearn the TPMS is in your owners manual, Links in Donbrew’s signature for online version.
Old 11-04-2022 | 07:46 PM
  #85
PulpFriction's Avatar
Never been successful with the procedure in the manual, and it’s a PITA anyway. My tire dealer used to screw it up but have gotten better. Best luck is to take it to my Chevy dealer. They do it in about a minute, no charge.
Old 11-05-2022 | 11:22 AM
  #86
Probably because many 2010 all 2011 needs the tool, not the release procedure.
Old 11-05-2022 | 02:22 PM
  #87
Cheap Guy's Avatar
Well it's been several days and few hundred miles and not saying there's cause and effect - maybe just coincidence - but the TPMS light hasn't come back on. If it does, I'll explore the other avenues, but for now, all's good.
Old 11-05-2022 | 05:04 PM
  #88
Awesome, keep it clean and drive it often!
Old 12-02-2022 | 11:37 AM
  #89
flstss's Avatar
Originally Posted by Oldblue
This is the kit I ordered, much less shipping then the full stainless steel kit I installed in Oldblue in April of 2018. Much easier to put into place . The lines are good quality, the ends are preinstalled except the front end of the vapour line.
So this kit graphs the lines in just under the driver's seat. Has anyone had problems with the fittings provided? The fittings provided fit the hard lines perfectly that I cut under the vehicle. But trying to insert the tubing in the kit into the fittings provided in the kit was a no-go. The hose was slightly larger than the whole in the nut and the nylon feral provided. Had to improvise but just wondering if anyone else came across this.
Old 12-02-2022 | 12:31 PM
  #90
Never used that style kit, I went engine to fuel tank as the lines were rusty up under the footwell brake pedal area that clamp the lines weren’t to healthy looking!
Quick Reply: Fuel line follies!
