Heated side mirrors conversion with pics
Old Oct 9, 2017 | 10:33 AM
serch826's Avatar
I did my Heated side mirrors conversion very simple, bought two heated mirrors from this seller on Ebay:
CHEVROLET HHR 2005 - 2010 ASPHERICAL BLIND HEATED 12V MIRROR GLASS Left Side | eBay
Then i connected the mirrors wires with a 10 amp fuse on each to the fat "PPL" wire to the rear window defogger, situated on the driver side in the corner below the panel.
Drilled a small hole in the mirror from the side that is screwed to the door and placed the 2 wires with a female connector.
Then from the male connector those 2 wires in to the door and out to under panel.
Works perfectly, it is just to push the rear window´s defogger switch.
Old Oct 9, 2017 | 11:46 AM
Cool! Er, that’s hot!
Old Oct 9, 2017 | 01:59 PM
serch826's Avatar
Thumbs up
Thanks!
Old Oct 9, 2017 | 05:04 PM
Any chance you have pictures of removing the mirror? Or instructions at least.
Old Oct 10, 2017 | 12:36 AM
serch826's Avatar
I didn´t it because there are many Youtube and other that explain this very well.
Old Nov 8, 2017 | 10:32 AM
Cat Man HHR's Avatar
Here's a video for a 2003 Suburban. I'm going to say it's the same for the HHR.
The link he gave for the heated mirror only said for the left side. But he did left and right.
Also how did he run the right wires to the left kick panel area to tie into the purple rear defroster wire.
Heated mirrors would have been a nice option from GM.
Old Nov 8, 2017 | 10:53 AM
Here is the wiring diagram, and why to not wire directly to the switch.
Old Nov 8, 2017 | 12:58 PM
serch826's Avatar
Thumbs up
That´s correct!!!
Old Nov 8, 2017 | 01:43 PM
I can see where you would have a "bang your head in the wall moment" if you did it any other way.
I do like those replacement full size spot mirrors.
$45 a hit is a shocker.
Old Aug 15, 2018 | 05:21 AM
papa_jo's Avatar
I like heated mirrors in the mornings
NxlKing2304
Mods - Exterior
59
Dec 7, 2020 03:43 PM
Doctuh
May 11, 2010 04:20 AM
joshua_arndt
Dec 1, 2006 01:52 PM
O6ChevyHHR
Oct 8, 2006 09:26 AM
