How to add GM Remote Start without option AP3
Old 04-04-2010, 06:28 PM
Originally Posted by lefthandedrighty
i want to do this, but i dont even know where to start
could someone point me in the right direction?
what i mean by that, is show me exactly what to do and where the BCM is please
i have an 08, i have the proper fob, i have the remote start option 'on' in the dashboard, and all i get is flashing lights
i think this mod will work for me
That info is somewhere in this website, but if I remember correctly.... You want to look for the connector box located on the passenger side of the "waterfall". There you will find the wire that needs to be grounded.
donbrew is offline
Old 04-06-2010, 08:47 PM
agrandad's Avatar
I ha the same. Just my ligths flashed. The BCM is at the front passenger seat. there is a panel to the left as you are facing front. It is where the fuses are. You must scrape the purple wire on pin 3 and attached a wire and groung it. It will then start.
agrandad is offline
Old 04-07-2010, 06:35 AM
ufvj217's Avatar
im curious too if this would work on a manual.
ufvj217 is offline
Old 04-07-2010, 07:36 AM
oneton's Avatar
no !
oneton is offline
Old 04-07-2010, 04:54 PM
lefthandedrighty's Avatar
awesome grandad, thank you
this is pretty much what i was looking for
pics would be even more helpful, but i think i can get it from here
lefthandedrighty is offline
Old 04-10-2010, 07:49 PM
  #26
popkorn's Avatar
My understanding is that manual tranny = no remote start. Think about it. Even the manual tells you to put it first and pull the e-brake when leaving unattended. How are you supposed to start it in gear?
popkorn is offline
Old 04-14-2010, 03:43 AM
  #27
ufvj217's Avatar
well aftermarket remote starts will work with manual. you'd have to leave it in neutral though.
ufvj217 is offline
Old 04-16-2010, 09:06 AM
  #28
m40p's Avatar
Ok. So can someone point out exactly which wire to ground? And where did you ground it to? Thanks!!
m40p is offline
Old 04-16-2010, 11:19 AM
  #29
Sno White's Avatar
The open connector with all the wires showing is not the right connector. Pin 3 of the connector that you can just barely see in the lower right of your picture is what needs grounding. Pick any of the screws holding the BCM for a ground.
Sno White is offline
Old 06-05-2010, 03:39 PM
  #30
jwl4261's Avatar
Does anyone know if this is possible on a 2007. The wiring harness appears to be different as there are four PU wires in the harness and none of them are in pin 3?
Thanks
jwl4261 is offline
Quick Reply: How to add GM Remote Start without option AP3
