How to new Shift boot and short shifter.
Old 03-29-2009, 07:52 PM
crazysteve's Avatar
Here is my new black and red ultra-suede with my b&m shifter
crazysteve is offline
Old 04-20-2009, 02:45 PM
The Stever's Avatar
Having trouble replacing my shifter on my 06 LT Manual. I got the top of the shifter knob off but from there I am stuck.
The Stever is offline
Old 04-20-2009, 03:48 PM
oneton's Avatar
Start a page #1, Read all and look at all pic. It's all there
oneton is offline
Old 04-20-2009, 04:01 PM
crazysteve's Avatar
I think the none ss hhr are different.
Old 06-21-2009, 07:15 PM
CarlsSS's Avatar
Thanks for posting this How to Guide Crazysteve. It really helped me a lot to be able to put my shifter cable back on today. Got a little carried away with a speed-shift to 3rd!!
Another thing I would add is that it helps to get at the shifter assembly to also remove the plastic shroud below the boot. Remove the small rubber liner in the rectangular coin slot piece in front of the boot. Carefully pull and pry that plastic piece out. You will find (2) 9/32 head screws behind there. Once they are removed you can lift up the shround, carefully popping it up off the clips that are holding down the back edge. This gives you better access to the bottom of the shifter where the cables attach.
CarlsSS is offline
BlackHHR
05-04-2006 06:36 AM
Quick Reply: How to new Shift boot and short shifter.
