Turn Signal Canceling Failure Fix: Lots of Pics
Old 09-06-2017, 04:23 PM
  #81
OKIE SS's Avatar
Sure glad I bought a replacement before I took the old one out. The little nub on the white plastic piece that touches the spring and extends down into the cam was broken.
Thanks to all that helped - wasn't too bad a job, about 30 minutes from start to finish.
OKIE SS is offline
Old 09-06-2017, 09:38 PM
  #82
J W Davis's Avatar
Glad it worked out for you, isn't it nice to have your turn signal switch work again?
J W Davis is offline
Old 09-06-2017, 09:47 PM
  #83
OKIE SS's Avatar
Sure is.
OKIE SS is offline
Old 09-12-2019, 05:10 PM
  #84
rigacci's Avatar
I just replaced my switch because it would not stay when turning. But now it will not cancel! The old switch was definitely bad, as I had to hold the turn signal down when turning.
The "new" switch is brand new. It will hold the turn signal but at the end of the turn it will not return the lever t its place. So I was figuring that the cam on the steering column must be broken. Is there some way to tell if it is the cam or the switch? Did I get a bad switch?
And if it is the cam, how can you replace that?
Anyone have any exploded views of the steering column?
Thanks for any help.
Dave
rigacci is offline
Old 09-12-2019, 05:54 PM
  #85
Maybe the new switch is broken.
RJ_RS_SS_350 is offline
Old 09-12-2019, 06:55 PM
  #86
donbrew is offline
Old 09-13-2019, 08:58 AM
  #87
rigacci's Avatar
Fantastic! Thanks very much!
The cams on the steering column that cancel the turn signals are probably within the assembly of #6, wouldn't you think?
I will have to remove the switch and look down towards the steering column. I can't believe they would use something that would break off. But then....
Or could I have a defective new switch?
rigacci is offline
Old 09-13-2019, 10:21 AM
  #88
A defective switch, or the incorrect switch could be the issue. It's the white part in the switch that extends when the switch is activated, and it retracts when it hits the "cam". So check that white component in the switch.
whopper is offline
Old 09-13-2019, 11:44 AM
  #89
rigacci's Avatar
This was the switch I got. It states it is for an HHR.
Amazon Amazon
Anyone have any issues with this "CARBHUB" brand switch?
rigacci is offline
Old 09-13-2019, 01:04 PM
  #90
Are you double sure that it is snapped into place correctly?
Maybe pull the switch and ensure that the white trigger piece pops out when the switch is activated. You should be able to see the piece that flips the switch off with the switch removed.
whopper is offline
Quick Reply: Turn Signal Canceling Failure Fix: Lots of Pics
