Bought my first HHR, this forum is rad!
Last thing, I have in/on mine..
THIS. I have UltraViolet in the floorboards, and had it under the car, but because of improper seal of the harnesses underneath, shorted out, and no longer works.. (drunk buddy put it up. Seemed like a good idea at the time.)
I did the floorboard, and it still works. Go figure. ^^^ Their stuff is good quality. I just had s****y installer.
I really wish I had gotten more photos of it with them on, than I did. I have some at home, but currently at work.
I had 2 under the hood (2ft), one atop the radiator plastic shroud, and one under the latch handle pointed through the grille, and 2 short (3ft) width wise under the vehicle, one under the nose, and one under the cross support (holed bar), and 2 (4ft) length wise under the car (Front to back) under my rocker panels (you may have running boards.)
I bet they looked badass! May look into that in the future, myself. I had a couple questions: Being in MN, will the negative degree weather effect the plasti-dip on my vehicle's emblems? Also, is it possible to listen to music from my phone using the USB or Bluetooth? I get the notification "Load failure". Thanks!
Don't know about the BT.. I would imagine you just need to load some music on a thumbdrive for the USB, and scan it from the radio.
And for the plasti-dip give their homepage a read here....
aboard Kyle, and congrats on your new ride!
