Hey, I would order one but the wife said if it wont power the time machine I can't have it. Found this in the reviews. Not good for time machines, the gamma output is too high without properly calibrated EM shielding, and the needed quantum shift due to nuclear variation is why "cold fusion" is preferred plus the chronoflux matrix interface for a nuclear power supplied displacement device is like a 14' cube...
I bet Ahmadinejad's team are buying all they can.
Do you think they are just mad because they ran short of Blinker Fluid?
Are you blinkers sluggish? Do they make an annoying ticking noise? Do they not flash fast enough? Here's your solution. Little do people know, factory quality blinker fluid should be changed every 150,000 blinks. Our blinker fluid lasts ten times that. KaleCoAuto high quality synthetic blinker fluid meets the highest DOT standards while not being in the least bit DOT legal! KaleCoAuto blinker fluid provides you with thousands of hours of reliable blinking without the wear and tear on the flash-synchro's that the other blinker fluids cause. KaleCoAuto blinker fluid will not lose its viscosity even in the most extreme situations. Why buy that old dino-blinker fluid, when you can get our unique patented synthetic formula? Satisfaction guaranteed!! For use in any car.
Only $18.95 a quart from your friends at KaleCoAuto!
Well I'll have to look into that, I just use plain old boring Zymol AVS Aircraft Wax. I did make one addition to the avionics suite and flight instrumentation on the old girl during her refit, do yo think I'll need it?
Ever have a day set aside for flying only to have the "Met Office" ruin your plans?
Today was originally forecast to be the proverbial "Severe Clear" that every pilot dreams of, instead I've got a 400 foot foot ceiling with thunderstorms, and 14 knot winds from the North Northwest....ah snertz!
Anyway, I'm patient, and the Queen can wait for another day. I want to keep my takeoff to landing ratio perfect, and yes that includes the forced landing in the soybean field, because it was technically a landing...just not where I'd planed on landing that's all.
